Sputtering issue help!
Old Oct 23, 2011 | 04:53 PM
makizm69's Avatar
makizm69
Default Sputtering issue help!
installed push start in the car and everything worked fine but now i decided to hook up tach wire so it would start by pressing button once instead of holding.
after researching for a while i found out there is no tach wire in z and only way is to use injector wire or coil pack control wire. so i tested with one and it worked but with about second over crank so i decided not to do it for that reason.
after i took it out i go start the car and it started sputtering and sound like a tractor and when i tap gas pedal, idle drops and cel came on. if i unlug that coil pack it gets a bit worse so im not sure if it's a coil issue..
don't have a tool to check codes so i will grab one tomorrow but im more than sure it would be miss fire codes
any experts?
Old Oct 23, 2011 | 05:14 PM
Waiz's Avatar
Waiz
Moved to the correct subforum
Old Oct 25, 2011 | 04:08 AM
makizm69's Avatar
makizm69
code P0102 but im not sure how this helps me in this situation...
Old Oct 26, 2011 | 02:34 PM
makizm69's Avatar
makizm69
more codes came up after resetting p0300 then later p0301
after going through ecu reset process with gas pedal, next day car started and warmed up fine but was shaking a bit and then back to bugging as it was. p0102 is not coming up anymore, so this shaky symptoms possibly because of bad ecu :/
Old Nov 20, 2011 | 03:31 PM
hndumafia's Avatar
hndumafia
Any updates to this! My car has what sounds like the same issue, but started completely randomly one day.
Old Dec 12, 2011 | 09:47 PM
prez3636's Avatar
prez3636
Interested in any findings as well. Just posted a similar problem that started randomly for my car as well... 03 touring.
apex locator
Jul 23, 2021 02:27 AM
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
Depravity
Oct 1, 2015 04:49 PM
