Service Engine Soon - HFC/TP o2 Sensors (P0420 & P0430)
Old Oct 24, 2011 | 10:17 AM
OMG35S's Avatar
OMG35S
Exclamation Service Engine Soon - HFC/TP o2 Sensors (P0420 & P0430)
2007 Infiniti G35s 6mt Sedan
Inspection is coming up and I need some advice!
Exhaust set-up = Stillen Catback Exhaust with GTM Resonated Test Pipes.
Car is throwing codes P0420 & P0430, which is common for HFC/TP's. My GTM RTP's have the extended J-Bung for the rear o2 extenders but it didn't help and my car still throws the codes.
I put in some steel wool (2" long 1" diameter) into the J-Bung yesterday and it still throws the codes. It didn't take that much force or effort to insert the steel wool but it did seem rather secure? I'm thinking about adding some more steel wool? How much is too much and how little is too little?
I can't add any extenders because there is no room due to the already extended J-Bung of the GTM RTP'.
Seems like my options are going back to stock cats if the steel wool doesn't work?
Anyone know of any friendly inspection shops in NY?
Thanks!
Old Oct 24, 2011 | 07:54 PM
Bmurray350z's Avatar
Bmurray350z
just put your stock cats back on. its not hard whatsoever. then after inspection throw your TP's back on.
Old Oct 25, 2011 | 08:09 AM
djamps's Avatar
djamps
The j-bung itself or an exhaust leak could be causing the issue. I threw no codes for 2 years with no 'hacks' or j-bungs on my HFC's. Now I have them deleted with an Osiris flash.
Old Oct 27, 2011 | 10:57 AM
OMG35S's Avatar
OMG35S
I managed to pass inspection today! After a lot of trial and error with steel wool, obdii scanner, Factory Service Manual and driving techniques, my car did not throw any codes.
Thanks again for the feedback.
etkms
Jun 19, 2022 06:30 PM
liqalu04
Jan 2, 2022 12:58 PM
Dr.Paulyy
Jul 29, 2019 07:45 AM
350z_z33.
Jul 3, 2017 04:01 AM
RyansZ33
Sep 15, 2015 05:54 AM
