No running lights!!! Engine light ON.
I was installing my new sound system yesterday in my '03 Z Enthusiast, when I plugged in the antenna wire into the back of the unit and there was a spark, which then I noticed (after I hooked everything up) that my engine light was on and that none of my running lights will light up. I believe the cause of the spark is because my stupid self did not disconnect the negative terminal of the battery. The rear lights will not come on until I press the brakes and only the main headlights will go on, which means I cannot drive at night until I fix this problem. Is this a blown fuse that i can replace and everything will work correctly? Or is this a more serious problem that I will have to seek professional help for?
uhhh how bout u try checking the fuses first
although from the sounds of it u may want to support your local mechanic.... we need to eat too.
liqalu04
Jan 2, 2022 12:58 PM
