Going to the dealer tomorrow for a new clutch...
Old Dec 5, 2011 | 04:21 PM
STL 350Z's Avatar
STL 350Z
Default Going to the dealer tomorrow for a new clutch...
Dropping the Z off at the dealer tomorrow to have a new oem clutch installed (107,000 miles Z is all stock). Started getting a notchy feeling in the petal and when pulling out the car would shutter when the clutch started meeting the flywheel. I have also had 2 instances where it's slipped and I have finally broken down and made an appointment to have it replaced.
Now I normally do all of my own work but since the Z is so low and combined with my bad back from a discectomy surgery last year I have chosen it would be safer for myself to take it to the dealer. This is costing me... but I figure if they do it they are responsible for everything if something were to go wrong.
For those that have taken it to the dealer should I be on the lookout for anything like them calling and saying they need to order more parts other than the clutch? I've just heard about dealers calling and saying they need to replace "such and such" or "we found this too" or surprise you with another price when you go to pay.
Does the dealer replace the clutch fluid as well and is there a warranty on a new clutch? I of course will be asking all this tomorrow but just wanted to ask those with previous experience...
Old Dec 5, 2011 | 05:30 PM
Looch's Avatar
Looch
What year do you have? If it's a 2003 you may want to consider replacing the clutch pivot joint as there have been instances of it failing in 2003's. They make a stronger one for $40 that you can find if you google it. Mine just snapped and now I have to pull the tranny to replace it so you might as well. That is, if it's a 2003.
Old Dec 5, 2011 | 08:35 PM
STL 350Z's Avatar
STL 350Z
I have an 05
Old Dec 5, 2011 | 09:25 PM
albinobob's Avatar
albinobob
As long as you’re forking out the cash make sure they do everything while they’re in there
Throw out / release bearing
Pilot bearing
clutch pivot joint (chromoly clutch pivot joint cost like $30)
Most of the cost is in the labor of dropping the tranny. There’s (or at least shouldn’t be) any labor cost for replacing the components above is they’re already doing the clutch. Then you’ll be good to go for quite awhile.
Old Dec 6, 2011 | 11:40 AM
STL 350Z's Avatar
STL 350Z
Pilot bearing
Dropped it off today and all those things you mentioned are being replaced as well as new clutch fluid. They also noticed a brake caliper sticking that I wasn't even aware of but you could smell.
One thing I was not told about is an $80 diagnosis fee...
At lest I know the master mechanic that's working on it so it will be done right.
Old Dec 6, 2011 | 01:22 PM
zakmartin's Avatar
zakmartin
Diagnosis for WHAT?? You just want your clutch replaced, you're not in for a 30,000 mile check-up. I'd contest that charge.
Old Dec 6, 2011 | 01:51 PM
STL 350Z's Avatar
STL 350Z
Once all the work is done I will... I'm not paying for something when I have already done the diagnosis myself.
Old Dec 6, 2011 | 09:01 PM
masphx's Avatar
masphx
You should not have to pay the 80 fee if you are getting the clutch replaced. Like other shops the 'look over the car fee' should be waved if you are getting it serviced. Especially for a costly job. Typically Dealer BS.
Old Dec 7, 2011 | 10:59 AM
STL 350Z's Avatar
STL 350Z
Dealer called... says there is nothing wrong with my car and doesn't need a clutch. Do they drive it everyday? Nope...
So guess what... I will just do the work myself when I get chance and when I can get into a friends heated garage.
Pleask
Dec 21, 2021 03:17 PM
07ZEKE
Aug 23, 2021 09:15 PM
350Z_Al
Oct 29, 2020 07:44 PM
ablaine
Nov 29, 2016 10:13 AM
Ronso
Oct 30, 2015 12:39 PM
