Where should the initial RPM be at startup?
Old Dec 24, 2011 | 08:32 PM
gunny16's Avatar
gunny16
Default Where should the initial RPM be at startup?
Hi guys,
I was driving my brother the other day and he made a comment during my car startup that the RPM noise is rather high. During a cold start, the RPM needle jumps to 2000 initially. It drops to 1100-1200 until it warms up. At that point, the RPM is sub-1000.
My only concern is whether the 2000 RPM at initial startup is something to be concerned about?
Thanks everyone.
Old Dec 24, 2011 | 09:14 PM
R350Zz33's Avatar
R350Zz33
When it's cold then idle is higher it's like this with every car
Old Dec 25, 2011 | 02:06 AM
hyuk28719's Avatar
hyuk28719
your car is fine.
Old Dec 25, 2011 | 02:45 AM
JCITY's Avatar
JCITY
Cool Don't listen to your brother
Originally Posted by gunny16
Hi guys,
Thanks everyone.
First of all,I've learned that brothers don't know jack s-it.
Secondly,in answer to your question---NO.
Old Dec 25, 2011 | 04:29 AM
DavesZ#3's Avatar
DavesZ#3
If you're concerned about the idle, you can always run the learning procedure and it should correct any problems you might have....
https://my350z.com/forum/6008226-post2.html
Old Dec 25, 2011 | 04:46 PM
gunny16's Avatar
gunny16
Default thanks!
Thanks everyone. I will try to refrain from asking too many noobish questions
Old Dec 27, 2011 | 11:00 AM
Earmuffs's Avatar
Earmuffs
Yeah I discussed this with a few mechanics. They explained catalytic converters need to be hot to do their job and when the car is cold it raises the RPM's to get them hot quicker.
In my case I have an '08 HR with test pipes and idle starts high even when warm out. Since it can't get a reading from the cats, that aren't there, it just operates on the assumption they are cold and need to be warmed up. The starts at ~2000ish and slowly lowers to aroudnd 900 over a few minutes when warm. I dont know about cold starts as it has been in the shop when I have been paying attention. But I think it is safe to assume that would take longer.
Hope this helps
Old Dec 27, 2011 | 01:37 PM
Deteria's Avatar
Deteria
Cold starts around 2k. After a bit it lowers to ~900
lapham3
Oct 7, 2022 03:15 PM
Justin100
Nov 29, 2015 03:58 PM
Depravity
Oct 1, 2015 04:49 PM
Tochigi_236
Sep 27, 2015 03:40 PM
Bigsyke
Sep 11, 2015 06:19 PM
