Air bag/ after market steering wheel question car won't start
Old Feb 4, 2012 | 12:15 AM
ZSpectrum's Avatar
ZSpectrum
Default Air bag/ after market steering wheel question car won't start
Sooo I installed an nrg hub and qr and now my car won't start. It's throwing nats codes as well as the flashing air bag light(I don't care about the light) I have a few questions, how/ why did this happen(nats) and how can I fix it? I think it's p1614 or possibly p1615. It shows up on the onboard, but my obdii scanner says I dont have any codes.
Do I need a drivers side steering wheel air bag for the car to start? Do I have to use the resistors so it will start? If so what resistor is it? I have one that came with the nrg hub.
Thank you, I just want my car to start so I can go slide around!!
Old Feb 4, 2012 | 01:16 AM
NismoZR's Avatar
NismoZR
You shouldn't . Check ur fuses maybe u trip something during removal. The air bag light would not affect ur start up. Also check ur fuse box under the battery compartment.
Old Feb 4, 2012 | 01:17 AM
NismoZR's Avatar
NismoZR
I can send u link how to make ur resistor to override the air bag light if u want.
Old Feb 4, 2012 | 05:24 AM
ZSpectrum's Avatar
ZSpectrum
Hmmm this just gets weirder. The only thing I can think of is I used that stupid sandwich grounding ring between the hub and quick release. Maybe I shouldn't have?
Old Feb 4, 2012 | 05:47 AM
ZSpectrum's Avatar
ZSpectrum
Also does anyone know if you use that grounding ring?
Old Feb 4, 2012 | 06:42 AM
ZSpectrum's Avatar
ZSpectrum
Update: my positive terminal is corroded to heck. I removed it when installing the wheel along with the negative. Could the corroded terminal be the cause?
Old Feb 4, 2012 | 07:46 AM
Voboy's Avatar
Voboy
^- was going to say check your battery connection when u disconnected the ground to install the steering wheel... no other reason for the car not to start after a steering wheel install..
Old Feb 4, 2012 | 10:12 AM
ZSpectrum's Avatar
ZSpectrum
Its good to go now, car still won't start. I even put in the proper resistors for the air bag, which turned off the airbag light. This is ********!
Old Feb 4, 2012 | 11:26 AM
bbs350z's Avatar
bbs350z
how dead is your battery? alternator? starter? does it crank? maybe it went into theft mode?
Old Feb 4, 2012 | 11:48 AM
NismoZR's Avatar
NismoZR
Try disconnect the battery for a few minute and then start the car maybe BBS350z is right your battery might be dead too. Try to sand your terminal so there is contact. The ring btw your hub and quick release serve as a ground for your horn to work I have it on mine no problem. Did you check the fuse box under your battery and yes you would have to remove your battery to check it. It happened to me yrs ago my reverse fuse blew and my z won't start towed to the mechanic and he found it was just the fuse.
Old Feb 4, 2012 | 12:19 PM
ZSpectrum's Avatar
ZSpectrum
I gave up. Battery was good, im towing it to a local tuner to eliminate all of the Nats stuff since that's what code it's throwing.
Old Feb 4, 2012 | 12:20 PM
ZSpectrum's Avatar
ZSpectrum
Also I left the battery disconnected overnight thinking it would clear this. It didn't. Thanks for everyone's help.
Old Feb 4, 2012 | 01:08 PM
Voboy's Avatar
Voboy
the only other thing i can think of is you messed with the NATS wiring where it doesnt detect the immobilizer chip in your key. but im not sure how you could have touched that stuff unless you forgot to plug something back you removed.
Old Feb 4, 2012 | 02:41 PM
ZSpectrum's Avatar
ZSpectrum
Na I didn't touch any nats wiring. The cars fixed, my fix was to eliminate every nats code as well as the global one.
etkms
Jun 19, 2022 06:30 PM
reno56
Interior
17
Nov 20, 2015 05:21 PM
Vigman
Nov 17, 2015 04:34 AM
RyansZ33
Sep 15, 2015 05:54 AM
Beater350z
Sep 9, 2015 03:36 PM
