No cabin lights, fuse is good, what might be wrong?
Feb 9, 2012 | 06:38 PM
Cabin and visor lights aren't working but trunk lights do, which both run on the same fuse in my 03 350z. Am I wrong or missing something?
Thx
Feb 9, 2012 | 06:42 PM
Maybe the lights are just burned out
Feb 9, 2012 | 08:05 PM
Recently started experiencing the same problem. They were off for about a week before replacing a bad positive battery terminal. While replacing they turned on momentarily, then back off for good again. Bulbs and fuses all check out, so I'm as lost as you OP.
Feb 9, 2012 | 09:25 PM
common problems on the z. just remove the neg terminal for a few minutes and it should work again
Feb 9, 2012 | 09:34 PM
I had this happen as well. Pretty sure it is BCM related. Removing the negative terminal should do the trick.
Feb 10, 2012 | 09:01 AM
I had this problem... Ended up being a fried interior dimmer switch
Feb 10, 2012 | 01:14 PM
Quote:
Originally Posted by
sleeper400
and how was this fixed?
Feb 10, 2012 | 01:20 PM
kevincat
I would assume by replacing the interior dimmer switch.
Feb 10, 2012 | 04:09 PM
Vivid Racing
is the dimmer switch the cabin light assembly?
afaik if removing the neg terminal for a few minutes doesnt work then you have to replace the bcm.
Feb 10, 2012 | 05:43 PM
If nothing else works, I've heard that replacing the car works too.
/sarcasm
Dimmer mechanism sounds like a likely culprit to troubleshoot next.
Feb 10, 2012 | 09:23 PM
where is this dimmer mechanism that you speak of? i googled it and all i got is the headlight dimmer switch
Feb 11, 2012 | 02:25 PM
Thanks a whole bunch! Cleaned and reconnected the negative and everything's all good.
Feb 15, 2012 | 04:44 PM
I had the same issue. What solved mine was the big fuse under the hood for the BCM. I pilled it out and put it back in and it works fine now. It is the green fuse block on the battery terminal.
Jambo016
Sep 16, 2016 01:08 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
2003 ,
350 ,
350z ,
370z ,
cabin ,
fuse ,
interior ,
lamps ,
leo ,
light ,
lights ,
my350z ,
purchase ,
trunk ,
work
