Steering!!! Help please :)
Old Mar 5, 2012 | 10:22 PM
tw8715's Avatar
tw8715
Default Steering!!! Help please :)
Alright changed my ac and steering belt and now my steering feels like there is no power steering at low speeds~
I recheck all and everything thing seems to be in order.
I drive the car with the steering wheel at the lowest position, when I raise the steering position it feels a little better! Seems like power steering comes back a little.
Any ideas what's going ???
Old Mar 6, 2012 | 08:02 AM
drivessidewayz's Avatar
drivessidewayz
Are you absolutely sure the belt is set right? Also I lose most of my power steering while doing any hpde, so...I'm actually in to see if there's something I can fix too.
Old Mar 7, 2012 | 07:49 PM
tw8715's Avatar
tw8715
It makes squeeking noise too when turning the steering wheel at slower speeds
Old Mar 8, 2012 | 01:01 AM
tw8715's Avatar
tw8715
Check engine light on now gonna go pull the code tomorrow
Old Mar 8, 2012 | 05:18 PM
tw8715's Avatar
tw8715
Got a p1273 code. I think it has nothing to do with steering. The squeaking sound is coming from inside the cabin right behind the steering wheel
Old Mar 8, 2012 | 06:07 PM
CTS13's Avatar
CTS13
Is that the code for bank 1 lean condition? How the heck did you manage this one lol.
Did you retighten the tensioners after you put the belts back on? Not sure how mechanically inclined you are but make sure your belt tension is okay. Kinda hard to help you much over internet, have someone else take a quick look.
Old Mar 8, 2012 | 09:31 PM
tw8715's Avatar
tw8715
Yea I tighten everything. Could it be that I over tighten?
I dont think it's loose cause it not squeeling
Old Mar 9, 2012 | 01:24 AM
tw8715's Avatar
tw8715
Also once in awhile power steering comes back lol
Old Mar 9, 2012 | 06:00 PM
tw8715's Avatar
tw8715
Power steering is back now. So weird.
Old Mar 10, 2012 | 04:14 PM
CTS13's Avatar
CTS13
Could be you had air in the system and bled out. idk
also just for future reference, to check tension, take the longest part of the belt between 2 pullies and twist it, it should turn 90 degrees, if it doesnt too tight, if it goes more, too loose.
Old Mar 10, 2012 | 04:58 PM
tw8715's Avatar
tw8715
Awsome thanks!
aarrgghh
May 1, 2022 11:04 AM
HoBrahYouStink
Jun 24, 2016 10:58 PM
Depravity
Oct 1, 2015 04:49 PM
dragon11689
Sep 7, 2015 02:47 PM
