Has anyone had their tires replaced by dealer for rumbling noises???
Old Dec 30, 2003 | 12:10 PM
fernandito7's Avatar
fernandito7
Default Has anyone had their tires replaced by dealer for rumbling noises???
Just wanted to know if anyone has had thier front tires replaced by their dealership due to the rumbling noises it makes when u brake. I am getting this loud rumbling noise when i brake and its so annoying. I a lready had the alignment fixed. Also if u have had this issue fixed, what did u tell the dealer, regarding the noise of course? Thanks
Old Dec 30, 2003 | 05:52 PM
jj1814's Avatar
jj1814
Tire feathering issue - check the Problem/Maintenance forum or do a search.
Old Dec 30, 2003 | 05:56 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
This is due to the tire feathering problem. Do a search on "Tire Feathering" and you will find more information on this site than just about ANY other subject.
There is a TSB (a technical service bulletin) on this noise. You should simply take the car to the dealer and tell them about the noise. You can refer them to TSB Ntb03006
Here is Nissan's actual text for this TSB:
Ntb03006
IF YOU CONFIRM: An applied vehicle shows the following symptoms when braking moderately: • excessive tire "roar" or "growl" noise, mostly when braking at speeds below 30 mph. ACTIONS: Verify the incident noise as described above. • Check alignment. Adjust (if needed). • Rotate front tires from side to side, dismounting tires from wheels. See this bulletin for detail.
As you can see, they will swap the tires from right to left after removing them and remounting them "inside out". This will solve the rumbling since the feathered part of the tire will now be on the outside whereas it was on the inside of the tire before the swap.
This is only temporary though as it will eventually happen again. Make sure you request a 4 wheel alignment after they do the swap to prolong the return of the feathering as much as possible.
When it does come back, then ask your dealer for new tires.
Good Luck
Old Dec 30, 2003 | 10:03 PM
fernandito7
Ok thanls. I read the other posts and they say that if the dealership does not want to work with me regarding this issue that to call NNA but what does NNA stand for? I did a search but nothing comes out. Please help. THaniks
Old Dec 31, 2003 | 03:00 AM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
Nissan North America
http://www.nissanusa.com
Nissan Consumer Affairs
P.O. Box 191
Gardena, CA 90248
(800) NISSAN-1 (or 800-647-7261)
9:00 a.m. - 6:00 p.m. Eastern / Central Time
8:00 a.m. - 5:00 p.m. Pacific Time
Old Dec 31, 2003 | 05:47 PM
boxsterkiller's Avatar
boxsterkiller
Ferandito,
The I went in for the drifting to the right problem and the first time they just set my front alignment to spec. toe-in was off. The drifting did'nt go away. The first time I asked if I would need new tires and they said they were cupping(feathering), but it was O.K.
The second time I was able to get them to order me two front tires which are on back order, that was in Sept. It is beyond the dealers control they say they are waiting for tires to come in. For now a lower control arm was also thrown in. The cupping/feathering on your tires is making the growl sound. Get new front tires and ask about the lower control arm.
Old Jan 1, 2004 | 11:18 AM
fernandito7
Thank u for all the info. i will be taking my car to the dealer on tuesday to have this fixed. This growl is so annoying. Not even my dads 4x4 makes this noise. Thanks again
Old Jan 1, 2004 | 12:02 PM
MY350Z.COM's Avatar
moved
07ZEKE
Aug 23, 2021 09:15 PM
ablaine
Nov 29, 2016 10:13 AM
Stevo Z
Oct 3, 2015 09:14 PM
samansharif
Sep 25, 2015 12:31 PM
