Clicking noise, left rear on acceleration?
Old Dec 30, 2003 | 05:02 PM
CottonWoodz's Avatar
CottonWoodz
Default Clicking noise, left rear on acceleration?
Has anyone fixed this problem yet? Its a clicking noise from the left rear wheel area. It clicks only on acceleration, and in reverse only on acceleration.Its been doing it for the last 5-6K miles, and its doing it more frequently now.
I know alot of people have this problem, and did a search for it, but this site needs some serious work done to their search engine.Thanks
Old Dec 30, 2003 | 05:21 PM
Jeff@Performance's Avatar
Jeff@Performance
Performance Nissan
Easily repaired. I believe there is now a TSB on it. Your dealer needs to disassemble and lube your axle splines...... if I remember right.
Old Dec 30, 2003 | 06:42 PM
CottonWoodz
Thanks Damn I knew it had to be the axle, cause like I said only when load is applyed it clicks.
I had my dealer look for the problem 2 times now, but was never fixed. I will bring what you said to my dealers attention, and see what they have to say.. Thanks again
Old Dec 31, 2003 | 04:59 PM
boxsterkiller's Avatar
boxsterkiller
I had the same symptoms and took mine to Performance Nissan and they did what Jeff said no more problems. Rocky did a great job.
Old Dec 31, 2003 | 05:06 PM
JonsilvZ's Avatar
JonsilvZ
I had the clicking noise from the rear. Axle nuts were tighten. A month later,different noise from rear. Driveshaft nut were tighten. So far after couple thousand miles, no problems. Damn must be the torque
Old Jan 4, 2004 | 09:30 PM
Z PHAT Z's Avatar
Z PHAT Z
Anyone know what's the TSB number? I looked at the resource forum but no luck. Thanks.
Old May 12, 2005 | 08:48 AM
flyboi12ichie's Avatar
flyboi12ichie
wow , thanks guys, i had the same problem too.. i thought my car was fallin apart already... either that , or i had defective rims. I called the service dept and told them my axles were clickin. Going in today to get it fixed.
Old May 13, 2005 | 06:11 PM
ADMAN's Avatar
ADMAN
Either that, or it could be your hubs. I had to replace my passenger hub before the wheel feel off. Now, the driver's side is doing it too. Note the way the rear end "wiggles" under heavy accelleration without losing traction. Yep, you got a hub problem too. Get it fixed before your wheel falls off as well.
P.S. I track my car A LOT. So, know where my problem comes from...
Old May 23, 2005 | 06:52 PM
kws's Avatar
kws
can u tell me where is it?????
they said he don;t think about it
my dealer is too suck
Old May 23, 2005 | 07:07 PM
ensmuns's Avatar
ensmuns
TSB here: http://www.nissan-techinfo.com/nissa...ayII/54538.asp
Old May 23, 2005 | 07:14 PM
kws's Avatar
kws
i done it, after 15000 km , the sound coming out again
but still had a clicking sound, they said they had reallly no idea on it.
so that why i ask anyone to know where is "Driveshaft nut". i want point it to my dealer, and they don't think re-torque any nuts can help the sound gone.
who can help me ............please........i will be crazy soon
Old May 23, 2005 | 07:23 PM
kws's Avatar
kws
Unhappy
buddy
did you fixed your track 350z?? after i back from track day. the sound coming again. before i replace the wheel bearing and alex outter. the sound coming again after 1500km, hubs can make the a sound from rear side???
how to tell to my dealer to check it. because i went to track, do u think they will fix my car if i tell them i was ran on track.
is it easy to recognize the hubs had a problem???
thanks
Old May 31, 2005 | 06:52 AM
ZatoIchi's Avatar
ZatoIchi
Thread: Anyne who hears clicking from the wheels! View Single Post
09-21-2004, 07:42 PM #29
ZatoIchi
My 3rd Z Car
Trader Rating: (0)
Posts: 49 Just got mine out the shop today because of the window motor problem (they replaced the motor and regulator) and my SA gave me a copy of the Service Bulletin which shows the problem is the outer wheel bearing and axel joint assembly, the dust boot has to be replaced when you dissasemble the bearings.
SERVICE BULLETIN NTB04-065
affects all 2003 models and 2004 built before 2-14-04
description part #
Bearing assy, rear 43210-AL505
Axel outer joint assy 39211-73L00
Repair kit, dust boot outer 39241-73L28
Take the car to the dealer and tell them to bring up this TSB, they have to order the parts and fix under warranty
__________________
Brickyard ENTH 6sp
ZatoIchi
View Public Profile
Send a private message to ZatoIchi
Find More Posts by ZatoIchi
Add ZatoIchi to Your Buddy List
Old May 31, 2005 | 08:22 AM
seanlaw's Avatar
seanlaw
ditto on the last post...it fixed the problem for me!
Old May 31, 2005 | 09:56 AM
Acree's Avatar
Acree
i've been having this problem for the last 4k miles or so. i only 8400 on it right now. i'm taking it to the dealer today. thanks for the info guys
samansharif
Sep 25, 2015 12:31 PM
