ABS VDC SLIP lights are on
Old Mar 28, 2012 | 07:46 AM
eldeguz's Avatar
eldeguz
Question ABS VDC SLIP lights are on
What are the causes of ABS VDC Slip lights on? Mine is 2006 Touring. Thank you.
Old Mar 28, 2012 | 07:57 AM
Welcome. The slip light comes ON when the rear tires are slipping.
Old Mar 28, 2012 | 09:08 AM
F34RL355's Avatar
F34RL355
if u start doing some drifts or donuts, the slip stays on even after u stop, not sure why, turning car off resets the light
Old Mar 28, 2012 | 11:48 AM
Wild350z707's Avatar
Wild350z707
most likely throttle body
Old Mar 28, 2012 | 11:50 AM
Russ@Z1's Avatar
Russ@Z1
or low brake fluid
or bad brake switch
Old Mar 28, 2012 | 01:57 PM
vq35deZ's Avatar
vq35deZ
had the same problem, ended up being the brake switch was getting stuck and all those lights would turn on. put a lil lube on the switch and its been working for over a year with no problems
+1 on checking the brake fluid level
Old Mar 28, 2012 | 09:59 PM
Question
What tire sizes are you running?
Old Mar 29, 2012 | 07:16 AM
scotts300's Avatar
scotts300
You're welcome for the help.
(Beat davidv to the punchline).
Old Mar 29, 2012 | 07:21 AM
nick350's Avatar
nick350
a short in led aftermarket brake lights was my issue dealt with it for awhile because it was at the same time my clutch was going and i thought it was that
Old Apr 3, 2012 | 08:40 PM
Always happy to help. If you have other questions please do not hesitate to waste my time.
Old Feb 6, 2020 | 07:58 AM
Brandon z33's Avatar
Brandon z33
Unhappy Helpp!!!!
I also need help with this issue I just bought my 04 350z a few months ago, my ABS SLIP VDC, and BRAKE ligh tare on my ABS and VDC do not work at all I constanly lose traction and I recently got in a car accident becuase my ABS was not working. I have checked the relay in the fuse box and the the harness everything is plugged in and the fuse/relay is good. I dont know how to tell if the speed sensors are bad and my car is lowered on cut springs, I'm not sure if the previous owner purpously disabled these things for drifiting but I was wondering what else I should check to fix this issue. I know if the ABS is failing or the VDC that it will trigger all the lights and cause all those traction related systems to fail. Please help thank you...
Old Feb 6, 2020 | 08:09 AM
travlee's Avatar
travlee
Master
he hasnt logged in for 8 years, dont wait on an answer from him. have you thought about pulling codes?
Old Feb 6, 2020 | 08:28 AM
Brandon z33
Old Feb 6, 2020 | 08:31 AM
travlee's Avatar
travlee
Master
and what were the codes?
Old Feb 6, 2020 | 08:32 AM
Brandon z33
I got the codes read and it said a relay somewhere by the master cylinder this is all i could find
I also did some reading and it said it could be this also.
Old Feb 6, 2020 | 08:40 AM
Brandon z33
dont remember exactly, it was some relay, the one in the fuse box is good so is the VDC fuse.
Old Feb 6, 2020 | 08:57 AM
travlee's Avatar
travlee
Master
you know without those, we will all be guessing
Old Feb 6, 2020 | 09:04 AM
Brandon z33
Yea true I have a friend that has a non working g35 I'm going to test those parts and see if the problem gets solved. I'll let you know
Old Mar 10, 2020 | 10:14 AM
Jovany Arroyo's Avatar
Jovany Arroyo
I have an 2003 Touring model Z, recently I have come across a problem. When ever I start up my car and pull out of a parking lot, driveway etc, my car start to jerk really bad as if my breaks are kicking in and out. Once I hit second gear my VDC light turns on and the SLIP light follows. Everything seems to work perfect after that.
Now, everytime I start my care I have to turn off my VDC by hitting the button and take of in first then quickly shift to 2nd to avoid any jerking. I have seen that even if I have the VDC off, the problem isnt really gone till the slip light also turns on.
quick summary,
Turning off VDC and SLIP light on = No no jerking, runs ok.
VDC on or off with no SLIP light = Problems
Old Apr 1, 2020 | 01:00 PM
Brandon z33
okay so i just found out today that i actually have a touring coupe. whihc has cruis control. I have an aftermarket steering wheel an NRG quick release would me not having the buttons for the cruise control have to do with anything with the traction control. i was able to get the ABS light to go away. And fixed the ABS.
