ABS VDC SLIP lights are on
Old Sep 5, 2020 | 02:00 AM
Pbmata141's Avatar
Pbmata141
Default Code C1142
Hello I have a 350Z 2005 Ani ed, . my 3 lights VCD SLIP ABS are on even after I did reset it cleared all the other codes I actually fixed by replacing the items it showed me and this one was my last code to fix. Trying see is it's okay for me to drive it while I get enough funds to be able to take it in to get fixed? And does anyone know what this code means? I already canceled out the fuse they have been replaced.
How to tell if it's the wire or the whole and or the switch? Buying all four via RockAuto it comes out to 700 but if it's just 1 of the abs that are bad then all 4 would be a big plus is there way to see if it's 1 of the 4?
Old Dec 13, 2020 | 05:44 PM
Skylar Boothby's Avatar
Skylar Boothby
Default Same Problem Dont Know What To Do
Originally Posted by Jovany Arroyo
I have an 2003 Touring model Z, recently I have come across a problem. When ever I start up my car and pull out of a parking lot, driveway etc, my car start to jerk really bad as if my breaks are kicking in and out. Once I hit second gear my VDC light turns on and the SLIP light follows. Everything seems to work perfect after that.
Now, everytime I start my care I have to turn off my VDC by hitting the button and take of in first then quickly shift to 2nd to avoid any jerking. I have seen that even if I have the VDC off, the problem isnt really gone till the slip light also turns on.
quick summary,
Turning off VDC and SLIP light on = No no jerking, runs ok.
VDC on or off with no SLIP light = Problems
I have no idea what to do but I have the exact same problem... But it feels like the break vibrations come from the front right area. What is the problem?
El_350deldiablo
Jul 14, 2010 11:55 AM
maxevo
Apr 8, 2010 03:26 PM
Nismokingz33
Sep 15, 2009 04:09 AM
calin
Mar 21, 2009 08:08 PM
z33luis
Mar 21, 2008 05:17 PM
