Z overheated/boiling sound from radiator/hissing
Old May 6, 2012 | 12:39 PM
phreaktor's Avatar
phreaktor
Design Engineer
Houston, we have a problem.
Attached Thumbnails Z overheated/boiling sound from radiator/hissing-306141_554815135183_132201645_30533771_745954611_n.jpg
Old May 6, 2012 | 12:44 PM
RandomHer0's Avatar
RandomHer0
Good job!
Old May 6, 2012 | 12:51 PM
350Zdj's Avatar
350Zdj
LOL. So it didnt open up?
Old May 6, 2012 | 03:43 PM
phreaktor's Avatar
phreaktor
Design Engineer
Replaced TS and I am still overheating. I don't think my fill/bleed process is correct. Bottom hose is still cold and so is the heat until I drove it to the point it was overheating and then it came on for a second and my temp started to go down. I'm sure there is still a lot of air in the system.
What is the proper technique for filling and bleeding the system if you don't have the Lisle funnel?
Old May 6, 2012 | 03:52 PM
Neimad's Avatar
Neimad
Get it on an incline, engine side up, start it cold with rad cap off. Keep the radiator full while it warms up, hold it at 2000 RPM or so if you want to do it faster. You should see bubbles come through radiator if theres much air. When its hot and seems full and no bubbles cap it, fill reservoir and test drive. There's a OEM bleeder screw somewhere but my method is fool proof and works with most cars. You could have weak water pump too if this don't work.
Old May 6, 2012 | 03:55 PM
phreaktor's Avatar
phreaktor
Design Engineer
What about the heat issue? And the lower hose being cold?
Old May 6, 2012 | 03:56 PM
Neimad's Avatar
Neimad
Thats why I worry about pump.
Old May 6, 2012 | 04:19 PM
RandomHer0's Avatar
RandomHer0
I had the exact same scenario, it was just air. Burp burp burp!
Old May 7, 2012 | 03:59 AM
phreaktor's Avatar
phreaktor
Design Engineer
The pump seems to be working as the top hose has that "swell and surge" to it. Correct me if I'm wrong, but wouldn't the hose offer little resistance when squeezed if it was the water pump?
I keep saying it's air, but in order for the system to be bled, wouldnt the TS have to be opening which would mean the lower hose would be hot as well? Is my new TS not opening as well? WHen I removed the lower hose to pull the TS, there was a good 3 inches of air in the hose and I could see the fluid a little ways down.. NO fluid came out of the hose.
Old May 7, 2012 | 05:57 AM
Neimad's Avatar
Neimad
No coolant came out of the bottom hose? You checked radiator for restriction? I couldnt see the pic you posted, did the old ts brak apart? Pressurization sounds good for pump and cap functional.
Old May 12, 2012 | 10:33 AM
phreaktor's Avatar
phreaktor
Design Engineer
FIXED!! Ran the car with the rad cap off til it warmed up, revved to 3K for 10 seconds, mad bubbles, let it cool, refill,. repeat, put cap on when the level no longer dropped, cracked open bleeder while running until all the air was out and refilled. Hot heat and no issues.
Thanks guys.
Old May 12, 2012 | 11:38 AM
RandomHer0's Avatar
RandomHer0
Good to hear!
Old May 12, 2012 | 02:26 PM
350Zdj's Avatar
350Zdj
Seems like our engine is very prone to having bubbles in the cooling system. I've had this issue few times already.
Old May 13, 2012 | 07:41 AM
DaveJackson's Avatar
DaveJackson
Master
^ Yep. It's ALWAYS air. Phreaktor's T-stat was probably fine but when a bubble rests against it the heart can't transfer well enough to trigger it to open.
I don't have the magic funnel, but I followed the filing instructions very carefully and I think that is important. You fill it extremely slowly.
Old May 29, 2012 | 06:32 PM
Phanta C racing's Avatar
Phanta C racing
My 2008 just did the same yesterday, just took in the shop for the same problem except I did leak coolant but then once I refilled it nothing leaked, I couldn't hearvor see the cooling fans turn on either, fuses were ok ,oil was good didn't smell like.coolant, so im assuming its the thermastat, odd thing was my AC wasnt as cold as usual
Obadabot
Jun 18, 2023 11:31 PM
wanderingstuden
Jan 28, 2016 07:03 PM
Justin100
Nov 29, 2015 03:58 PM
samansharif
Sep 25, 2015 12:31 PM
