Oil Consumption Mystery
Old May 6, 2012 | 03:54 PM
Raginraj11's Avatar
Raginraj11
Default Oil Consumption Mystery
So my car has been burning oil for the past 30k miles, i put in 1.5qts every 2 weeks. Had a compression leakdown test done yesterday and compression was 150 across all 6 cylinders. There is no visible oil leak. Car has a slightly rough idle, was worse before the spark plugs were changed. Car blows out light gray smoke during city driving. Im wondering what else could be causing the OC and smoking? Valve covers/gasket were replaced by Infiniti about 25k miles ago, did not help the OC problem.
Mods are: ztube/popcharger, 5/16 spacer, aam hfc, FI cat back exhaust, Osirus Tune.
BTW car was denied a longblock by Infiniti due to pop charger and cat back exhaust, 2 yrs ago
Old May 6, 2012 | 04:49 PM
Let me see if I have the numbers right. You are adding 39 quarts/year? I don't know where the oil is going but performance must be adversely effected. This motor is gone. Say bye-bye.
Old May 6, 2012 | 04:55 PM
herrschaft's Avatar
herrschaft
Either rebuild the motor you've got or buy a new short block, one with higher compression pistons would be better.
Old May 6, 2012 | 06:14 PM
Lee R's Avatar
Lee R
^ Compression ratio on pistons has nothing to do with oil consumption or making this engine run better. Stock piston ratio would be fine.
You need a leak down test. That will tell you how much is getting past the rings.
Old May 6, 2012 | 06:42 PM
herrschaft's Avatar
herrschaft
"Better for performance" is where I was going.
Old May 6, 2012 | 09:26 PM
Lee R's Avatar
Lee R
Wait a minute.....you have been having oil issues since 2009? Looks like you have already had tons of info thrown at you. You just have to get it taken care of.
https://my350z.com/forum/na-builds/4...ing-motor.html
Old May 6, 2012 | 09:39 PM
Raginraj11's Avatar
Raginraj11
Leakdown test was done and it was normal, which doesnt make sense to me. I thought the main problem was the piston rings which causes OC.
That sounds about right + or -.
Old May 6, 2012 | 09:44 PM
Raginraj11's Avatar
Raginraj11
What else could be causing the OC, since the compression/leakdown test were normal?
Old May 7, 2012 | 12:43 AM
Buster-here's Avatar
Buster-here
I would have thought 150 was a bit low.
Old May 7, 2012 | 07:06 AM
DaveJackson's Avatar
DaveJackson
Master
Comp test and leak-down test are different. Were both done?
Old May 7, 2012 | 11:21 AM
Raginraj11's Avatar
Raginraj11
yup
Old May 7, 2012 | 11:42 AM
Vivid Racing's Avatar
Vivid Racing
Vivid Racing
It's probably too late now, but Infiniti had no legal grounds to deny you a long block in 2009. Research the Magnusson-Moss Act.
Old May 7, 2012 | 01:22 PM
Raginraj11's Avatar
Raginraj11
Been there done that, no solution. Infiniti consumer affairs people are ruthless.
Old May 11, 2012 | 04:10 PM
Lee R's Avatar
Lee R
What were the leak down results (meaning number)?
Old May 11, 2012 | 04:55 PM
Stock2Autocrozz's Avatar
Stock2Autocrozz
Mileage??? Ive burnt my fair share of quarts...Dodge, Northstar ETC, need more info
Old May 13, 2012 | 03:50 PM
Raginraj11's Avatar
Raginraj11
wasnt given a specific number, just told that it was normal.
84k. Been burning since about 50k though
Old May 13, 2012 | 04:20 PM
0jiggy0's Avatar
0jiggy0
Do another compression test. Put a capful of oil in each cylinder right before each test. If it raises its rings. If it doesn't its probably in the valves. 150 sounds low though.
Old Oct 27, 2013 | 07:31 PM
AARONHL's Avatar
AARONHL
Is a dry test just a standard compression test and a wet test when oil is poured into the cylinder? Is the wet test a leak down test? Should these tests be done with a warm engine?
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
Stevo Z
Oct 3, 2015 09:14 PM
