350z Trunk WILL NOT OPEN!
Old May 29, 2012 | 08:22 AM
gabe123x's Avatar
gabe123x
Default 350z Trunk WILL NOT OPEN!
My trunk will not open via Key FOB or trunk button and the emergency hatch release is blocked by my subwoofer enclosure. when I press the button or Key fob it does not even make a sound, basically does nothing. Does anyone know a fix for this? I tried replacing the fuse to no avail.
Old May 29, 2012 | 09:29 AM
bmccann101's Avatar
bmccann101
nope.
youll have to move your woofer box man.
that emergency latch and the electric one are all that there is.
Old May 29, 2012 | 12:52 PM
gabe123x's Avatar
gabe123x
Regardless of whether i can open it manually or not, I still need to have the electric mechanism fixed. Anyone had this problem or any suggestion as to what it could be? I called the dealer and they said it may be the "relay" but I don't know what that is.
Old May 29, 2012 | 01:41 PM
bmccann101's Avatar
bmccann101
Theres a relay block by the battery, a fuse box behind the battery, and fuses and relays in the kick panel.
Old May 30, 2012 | 03:57 PM
zakmartin's Avatar
zakmartin
It's more likely that it's a bad actuator than a bad relay. Either way, it's easy to check your relays. Just do a youtube search on how to test a relay and if you don't think you can handle it, take it to a shop. Seriously, next to putting air in your tires, testing a relay is about as easy as it gets.
Old May 30, 2012 | 05:04 PM
sradenton's Avatar
sradenton
Theres a relay for the hatch. check the owners manual on the relays location.
http://www.theautopartsshop.com/auto...ase-relay.html
Mortivore
Jun 10, 2018 09:16 AM
dragonfire6
Jul 14, 2016 05:53 AM
Shmekal
Apr 19, 2012 11:08 AM
cessna
Nov 15, 2005 03:08 PM
alvareztony
Jun 30, 2003 06:22 PM
