Valve Lifter issues (cam followers) Engine Gurus chime in!
Old May 30, 2012 | 02:38 PM
Zachattack615's Avatar
Zachattack615
Question Valve Lifter issues (cam followers) Engine Gurus chime in!
2003 G35 coupe
Vq35de
6spd
103k
I bought this car with this tick and I am really wanting to fix it for good its annoying first of all second it cant be good. I have verified that it is the valve lifter lash making the noise.
I have also searched up and down and thank you for the good information i have already gained from here!
I have been messing with this car for a few days now and I have measured everything at least three times and checked my math several times. I have a pretty solid Honda background so i'm new to all this complicated quad cam timing chain stuff but i can manage that. My real issue is i have about 8 lifters out of spec and they have been that way since i bought my car. 2 of the lifters i can get replacements for the rest are too big of gap i assume and they don't make them sooo what causes the larger gaps and how do i go about getting my car back on the road? I'm about to upload my spec sheets i have if that will help any.
the Attatchments are pretty self explanatory the first one is valve lash and lifter thickness the second one is my math to figure out my new lifter thickness.
Thanks for the help ahead of time.
I was sent over here from g35driver btw
Old Jun 2, 2012 | 09:10 AM
Zachattack615
no input? yet? any info would be appreciated
Old Jun 2, 2012 | 09:51 AM
djamps's Avatar
djamps
I'm no expert but if the gap is too large it is probably due to worn out cam shafts, perhaps due to oil starvation at some point. That was your question, right?
Old Jun 2, 2012 | 03:47 PM
jerryd87's Avatar
jerryd87
are the cam bores in spec? measure the cam its likely its out of spec and will need replacement like djamps already mentioned. its one of the two im betting cams themselves though.
Old Jan 27, 2020 | 01:29 PM
Geroge's Avatar
Geroge
Default Lifter
Please if anyone sees this I have some questions I could really use help on so I bought a g35 with a ticking noise tore it apart and measured the gap between the lifter and cam and it’s to big to buy a replacement lifter I also measured the cam itself and it is well within spec what else could it be? Is there anything I can do to solve this?!? Please help and information is appreciated
Old Feb 3, 2020 | 03:11 AM
RobPhoboS's Avatar
RobPhoboS
What sizes did you record ?
Were the heads worked on at all ?
If they did, I wonder if someone forgot to put the washers in under the springs.
Fixxxercask
Nov 9, 2015 11:10 AM
350z82
Oct 1, 2015 06:25 PM
