New ball joint popping sound
Old Jun 9, 2012 | 04:52 PM
000's Avatar
000
Default New ball joint popping sound
I just installed a new adjustable upper control arm on my driver side...now when i go over bumps in the road it makes a load popping/clunking sound...everythings tight and i put the new little cone adapter in it so what would cause this? does the cone adapter have to be pushed onto the ball joint deeper down?
Old Jun 11, 2012 | 03:45 PM
zakmartin's Avatar
zakmartin
Have you been under the car to see if there's any play up there when you push the wheel assembly around? Did anything get damaged when you removed the OEM upper control arm? Did you use a separator or a pickle fork?
Obadabot
Jun 18, 2023 11:31 PM
07ZEKE
Aug 23, 2021 09:15 PM
Justin100
Nov 29, 2015 03:58 PM
samansharif
Sep 25, 2015 12:31 PM
