350Z spark plugs well engine oil issue. Serious Problem? Help Please
Hi
I have recently replaced the spark plugs on my Z.
When replacing the plugs, I found that there are engine oils in driver's side spark plugs well.
I have searched on the forums and seem like it is a common issue. It can be solved by replacing the gasket.
My question is, if I don't replace soon, will it cause any problem?
Thank you.
Thank you.
Here you go...
https://my350z.com/forum/maintenance...plug-well.html
and I would get anything dealing with oil leakage checked out asap.
i got the same issue while replacing my plugs around 25k. i bought all the gaskets to dyi and never did replace them. i do check the oil for leaks periodically, but so far it has not been an issue.
you can buy all the gaskets to dyi for about $100...or replace the valve covers at about $175 a pop.
good luck with it
good luck with it
r /d factory in el monte does the repair on your valve covers for 160 dollars. Ihad mine done.
cheaper then 200 a side for valve coveres.. btw OP the oil is not coming in from the valve cover gasket.. its from the seals in the top of the oil tubes.
https://my350z.com/forum/engine/5128...asket-set.html
and the one close to windshield have the most engine oil.
