Clutch and Flywheel trouble! Manual Install help please!
Old Jul 3, 2012 | 02:02 PM
enlopez's Avatar
enlopez
Default Clutch and Flywheel trouble! Manual Install help please!
So my oem clutch is completely trashed and I have already taken everything apart but had no idea that the stock flywheel was dual mass?
I looked everywhere but as I understand you can't get it resurfaced so i'm looking to buy a new flywheel and could use suggestions. The ACT street/prolite flywheels look appealing but I don't know if there are different procedures for that install? or how lightweight I should go? or what the side effects are for using a single mass flywheel on the Z setup.
ANY HELP WOULD BE GREAT. THANKYOU!!!
Old Jul 3, 2012 | 06:47 PM
Gozirra's Avatar
Gozirra
Jim Wolf Technology and ACT clutch and flywheel packages are popular. The JWT seems to get good reviews. A lighter flywheel obviously sheds some lbs, and on our car any weight off is good. I believe the biggest pro is that the car will rev faster with a lighter flywheel. Cons would include stiffness for a while, harder to get the car going in first gear because you have to rev higher, harder to rev match, and you'll have to relearn the new setup because itll have different grab points and responsiveness. Keep researching and hopefully someone will chime in because Im no expert on the matter.
Old Jul 11, 2012 | 09:42 PM
enlopez's Avatar
enlopez
Thanks man, anything helps. I ordered the prolite so its 20+ lbs lighter xD. At this point i'm mainly wondering if anybody knows if there is a different procedure for the install? Or if someone knows a good clutch install DIY in general...
Old Jul 12, 2012 | 05:17 AM
Exemption's Avatar
Exemption
from what i know its pretty standard...i have the nismo (wish i went with jwt), should come with the little tool to line it up properly and all. if not see if you can find a number to call.
Old Jul 19, 2012 | 12:01 PM
enlopez's Avatar
enlopez
Ya it went smoothly, everything installed moderately easily....except now that everything is back together I tested the clutch and it just stays in the down position. I have to manually pull it back up. I have no idea what I did wrong. I followed a DIY and everything....@_@
Old Jul 20, 2012 | 07:35 AM
easternriderkid's Avatar
easternriderkid
from my experience the clutch master aluminum is good i have the same one in my Z, rpm spins up real quick. however you wanted some side effects from being so light and a single your going to get a chatter in the fly wheel. when siting at a light you will hear it and trying to hit the gas under 2000 rpms it sounds like beer cans in your trans until you get to about 2500 rpm but i have had that flywheel in the car for 30000 mi and no issues but the noise. good luck to you sir.
Old Jul 22, 2012 | 08:02 AM
djamps's Avatar
djamps
You have to bleed it. Alot. It's a PITA. Also make sure you lined up the flywheel right or it's not gonna run .
Old Jul 23, 2012 | 07:43 PM
MrGlass's Avatar
MrGlass
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
