Rear Hatch button not working!
Old Jul 13, 2012 | 10:46 PM
jstar809's Avatar
jstar809
Default Rear Hatch button not working!
Ok so my rear hatch button isn't working at all; when I press the button nothing happens as well as the keyfob (but that already didn't work, I just used the rear button)!
Anyways, I checked the fuse and its fine. I have no idea what else it could really be.
Old Jul 13, 2012 | 11:20 PM
dkang's Avatar
dkang
maybe you somehow switched the button in the compartment behind the passenger seat? it's in an obscure place though. hard to accidentally hit.
Old Jul 14, 2012 | 12:02 AM
Waiz's Avatar
Waiz
I did a search for hatch not opening and found the following in the correct subforum (Maintenance & Repair):
https://my350z.com/forum/maintenance...wont-open.html
First thing I would do is try to get your keyfob working and use that to open all the doors then try to open the hatch
Old Jul 14, 2012 | 02:33 AM
JCITY's Avatar
JCITY
More than likely the actuator has gone bad not the switch.Its a common problem for this solenoid
to go out after time.The part costs about $225.I've replaced 2 since I've had my Z.
Pretty quick install...
Old Jul 14, 2012 | 06:39 PM
jstar809's Avatar
jstar809
ugh I hope not I will look at it on Sunday. more than likely i'll not fix it soon tho if its the solenoid, I got better things to do with $225 lol
Thanks for searching that for me Waizzz....and thanks for the heads up JCITY appreciate it!
dboyzalter
North East Marketplace
15
May 6, 2018 09:41 AM
BEBO'S ZEE
Jun 7, 2016 07:48 AM
bcoffee20
Nov 19, 2015 06:39 PM
Shane86
Sep 17, 2015 05:33 PM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
