Replacing AC Compressor
Old Jul 21, 2012 | 10:05 PM
acekid187's Avatar
acekid187
Default Replacing AC Compressor
Hello forum I dont start threads ever. But i have search all over. I need to replace my AC compressor. I dont think it would be hard. Just looking for a little in site in this misson. So if anyone out there can give me some info that would be great. Its a 2003 Touring edition. 5AT
Old Jul 22, 2012 | 01:23 AM
350zjason350z's Avatar
350zjason350z
Know it all
It's not hard at all... I just took mine off ... It's just a bracket , belt , and ac line .... Make there is no "free on " spelled wrong , charged b4 u loosen those lines ... Mine was empty so.... I sell u my compressor ...
Old Jul 22, 2012 | 02:40 AM
laurentj23's Avatar
laurentj23
Read the FSM and you will be fine!
Old Jul 22, 2012 | 12:17 PM
SxExCx's Avatar
SxExCx
I have one for sale if you need it. PM me if you are interested.
Old Jul 23, 2012 | 01:30 AM
acekid187's Avatar
acekid187
Thanks for the advice. Ill be giving it a try. I'll let you know how it goes
Old Jul 27, 2012 | 08:52 AM
stoffius's Avatar
stoffius
Make sure you wear gloves and protective eyewear in case there is freon in the system. When servicing one that I thought was empty for sure, I found there was still pressure in the low-port side.
Old Jul 23, 2025 | 12:59 PM
peafarmer's Avatar
peafarmer
5 Year Member
Default AC compressor torque values: mounting bolt and refrigerant nuts
OK, this is an old thread, looks like not many posting about the AC compressor replacement. We just replaced the compressor on my son's G35, there were a few videos which helped, was a relatively straight-forward job. The new compressor is back in and I have been scouring videos and forum for torque values for both the refrigerant lines on the compressor and the compressor mounting bolts. I don't have the factory service manual. I called the manufacturer that we bought the compressor from and the technician said just "make them tight".
Does anybody have these torque values? It looks like the compressor mounting bolts are M9 from measurement, and the head of the bolt has a dot on it with either a 6 or a 9 depending on which direction is up.
Thanks!
Andy
Old Jul 23, 2025 | 05:36 PM
icer5160's Avatar
icer5160
Hey Peafarmer,
The 3 bolts that hold the compressor to it's mounting bracket should be torqued to 45ft/lb.
The A/C line fasteners at the compressor should be torqued to 10ft/lb (or 120in/lb).
FSM ATC chapter
FSM ATC chapter
If you get a copy of the FSM, the chapter you want to look over is labeled "ATC" for "Automatic Air Conditioner." Took me a minute to find it since ATC does not equal AAC.
Cheers!
-Icer
Rev_Night
Nov 7, 2020 06:00 PM
350z82
Oct 1, 2015 06:25 PM
