View Poll Results: Have you replaced a clutch?
Yes. It was defective. (please note mileage below)
15.79%
Yes. I wanted something better. (not defective to my knowledge)
12.28%
No. It's still running strong. (note mileage)
30
52.63%
No. I think it might be going bad. (note mileage)
19.30%
Voters: 57. You may not vote on this poll
Have you replaced a clutch yet?
Old May 25, 2005 | 01:01 PM
CFZ's Avatar
CFZ
Had my tranny replaced the other day at 18,000 (grinding into 3rd) they replaced my cluch as well because they said the splines on the new transmission did'nt match up with the old clutch splines. The new clutch takes up about 2 inches later than the old clutch. Too late in my opinion. Dealer says this is not adjustable. Want the feel of my old clutch back. Can anyone help?
Old May 25, 2005 | 06:37 PM
Z BOY's Avatar
Z BOY
35.9k np. replacing with jwt cuz engine is out.
Old May 31, 2005 | 09:51 PM
ryanmac516's Avatar
ryanmac516
i like boobies
replaced mine with i got a new tranny with nismo parts found out that i needed one anyway so i saved myself a few hundred bucks by doing it then and not waiting till later
Old May 31, 2005 | 09:52 PM
ryanmac516's Avatar
ryanmac516
i like boobies
sorry at 22000 miles
Old Jun 1, 2005 | 05:34 PM
HOMiEZ's Avatar
HOMiEZ
30k OG clutch.
Old Jun 2, 2005 | 06:09 PM
zpeed350's Avatar
zpeed350
Ditto...the original clutch caught right off the floor....really liked it alot.
After the tranny replacement (3rd gear grind at 18,000) and clutch with it, it catches about 2-3 inches higher. I am used to it now, but really liked it closer to the floor. I got the same answer, it's not adjustable.
Old Jun 2, 2005 | 06:28 PM
pico350z's Avatar
pico350z
Negative and @ 12133 odometer miles, my Z rips my head backwards like an animal. rich, san jose, ca
Old Jun 2, 2005 | 07:04 PM
nbdyfcnsqnc's Avatar
nbdyfcnsqnc
My clutch had always seemed fine, but the dealer replaced it when the tranny went.
Old Jun 4, 2005 | 06:06 AM
Lawn Dart's Avatar
Lawn Dart
At 27k miles, my clutch left me stranded on the side of the road 30 miles from home. I noticed it slipping as I was driving up and figured I better order a clutch. When I was coming home, it went from ok to horrible in about twenty miles.
Old Jun 5, 2005 | 08:40 PM
CFZ's Avatar
CFZ
zpeed350, See my post in How's youre clutch feel? in the repairing fourum. westpak attached a tech sheet that helps. If you try this youreself you will need to remove the ASCD switch and, the rubber stopper on the pedal so you can get enough clearance to turn the clevis in, then readjust the ASCD switch according to the tech sheet.
Old Jun 8, 2005 | 01:53 PM
PAZee's Avatar
PAZee
I have the chattering problem with my clutch, I noticed this around 14k miles. I now have 28k and still have chatter, as well as throwout bushing noise which goes away when I push the clutch in. My dealer says they can't hear it and that the chatter is normal. I'm taken it in twice already and they must think I'm crazy.
07ZEKE
Aug 23, 2021 09:15 PM
sales@czp
Sep 23, 2019 03:30 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
