rattle noise at 1K-2K rpm in 1st, 2nd and 3rd
Old Jul 29, 2012 | 04:45 PM
boliviandaddy23's Avatar
boliviandaddy23
Default rattle noise at 1K-2K rpm in 1st, 2nd and 3rd
OK guys so im having this problem where when i pop it into gear first gear from 1-2k rpm it has a rattle noise and so on in every gear until 4th gear at the same rpm? the car has 29,XXX miles and its a 08...i don't know what it could be any one having the same problem or experienced this before?
Old Jul 29, 2012 | 05:25 PM
jduet's Avatar
jduet
You might want to get a mod to change the thread title first.
Old Jul 29, 2012 | 06:12 PM
huyrua's Avatar
huyrua
From the thread title some vender will post "pm me, price too low to post" so they can help you.
Old Jul 29, 2012 | 06:24 PM
SparkleCityHop's Avatar
SparkleCityHop
Living in 350Z
Yep.
Done.
Old Jul 29, 2012 | 06:28 PM
SparkleCityHop
Living in 350Z
Is this your first manual transmission car?
Why would you be at 1K-2K rpm in second and third gear as opposed to down shifting?
Old Jul 29, 2012 | 07:34 PM
boliviandaddy23
no its not but i meant like when im at a light i start in 1st gear and hit about 2,500-3000 then shift and so on...i like to shift around 3k when im tryn to make my gas last lol....but in those low rpms it rattles...not trying to get flamed or anything...but it didn't make that noise before..i had the car for for 3 years now and it just started like 2-3weeks ago now
Old Jul 30, 2012 | 03:02 AM
SparkleCityHop
Living in 350Z
I would not recommend shifting out of 1st at 2500 rpm. You're almost stalling your engine. That is what you are hearing. You are shifting too early and it is not saving you on gas mileage. Gas mileage is a factor of throttle usage, not low RPM.
Old Jul 30, 2012 | 07:26 AM
350ZZJoe's Avatar
350ZZJoe
What would you recommend shifting out of first at?
I am just curious. I shifted higher when I drove a 4cylinder Cobalt that had no torque until boost but this car has much much more torque.
I would not recommend shifting out of 1st at 2500 rpm. You're almost stalling your engine. That is what you are hearing. You are shifting to early and it is not saving you on gas mileage. Gas mileage is a factor of throttle usage, not low RPM.
Old Jul 30, 2012 | 01:27 PM
boliviandaddy23
ok we found the prob? so how do i fix it where do i look to fix it?
Old Jul 30, 2012 | 02:56 PM
SparkleCityHop
Living in 350Z
For best gas mileage, you want to maintain a low and steady throttle usage. I've also had my best MPG results by keeping the car's RPM within the range where the torque is highest (3200-3500 on my car). I believe this is because when the torque is highest, it takes less throttle to maintain your speed.
So there isn't anything wrong with your car, you just need to adjust how you are driving it.
Old Jul 30, 2012 | 03:01 PM
SparkleCityHop
Living in 350Z
Depends on what you're trying to do...
I shift at 6000 rpms when driving fast. Otherwise I shift anywhere from 4000-5000 if driving around in my normal "quick" fashion. If I'm cruising on the interstate for a long trip, I try to use whichever gear is appropriate to keep me in the sweet spot of the torque curve. If I'm driving around town, I could care less about my MPG - it's a sports car, I want to enjoy the feel of it, not stress over the gas mileage.
Old Oct 29, 2013 | 10:03 AM
andypants101's Avatar
andypants101
But I have the same problem and that's no matter when I shift I still hear the rattle from 1k-2k.. I thought it was a rod or something really bad but its not effecting my driving so it can't be just from when your shifting..
Old Oct 30, 2013 | 12:01 AM
rebelscum's Avatar
rebelscum
Does it sound like gravel being vibrated in a metal pan? I've been told this is normal .... Something about the flywheel design if I remember what my mechanic friend told me correctly... Worried me when I first picked mine up too, but I've heard it on other Zs now that I know to listen for it
Obadabot
Jun 18, 2023 11:31 PM
sherm
Apr 11, 2020 05:21 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
