procedure for break in on new final drive gears
Old Aug 3, 2012 | 09:29 AM
easternriderkid's Avatar
easternriderkid
Default procedure for break in on new final drive gears
hey whats up guy, just got my car back from the shop with the new 4.08 fd gears in it i was just looking for the proper way to break them in and the milage for dif oil change. so any one that could help please drop me a line. thank you
Old Aug 3, 2012 | 05:04 PM
ian99rt's Avatar
ian99rt
http://www.ringpinion.com/TechnicalHelp/FAQ.aspx#37
Follow that and you'll be good. Do not be tempted to lay into the throttle and really load up the gears.
I followed this procedure exactly and my 4.08s are practically silent with solid aluminum diff mounts.
Old Aug 3, 2012 | 05:26 PM
easternriderkid
thanks man you have been a big help you really seem to know your way around a car so to speak thanks a lot. by the way whats your take on the intake on the hr i have the aem system but most say a drop in with the stock system is the best way to go, what your take on it being we have the same year Z.
Old Aug 3, 2012 | 05:31 PM
ian99rt's Avatar
ian99rt
I try my best to know everything about everything.
Old Aug 3, 2012 | 05:58 PM
ian99rt's Avatar
ian99rt
Having done my research and overall engineering review I can say the HR has 2 options that will produce safe, consistent gains on an HR:
1) K&N drop ins, cheap and simple. Will give little to no gains but sound better and reusable.
2) Injen long tubes, not cheap and requires pulling bumper to install / clean filters. Gives proven gains without dangerously leaning the motor out ( Stillen long tubes trick the MAF sensors to lean out for a little extra power). That said, with nothing but a stillen catback exhaust and injen intakes my car was running a bit lean at wide open (14.0 AFR). Osirus reflash brought me back to a safe 12.5 AFR.
Old Aug 4, 2012 | 09:06 AM
Esser's Avatar
Esser
If you want a proper break in procedure, here is what we recommend:
-Avoid heavy acceleration during the break in process
-Drive the vehicle lightly for the first 15-20 min and stop. Let the differential cool before proceeding.
-Repeat this process for the first 100 miles
-Drive the vehicle at least 500 miles before towing anything
-Change the gear oil after the first 500 miles. This will remove any metal particles and phosphoric coating shed by the gear seat during the gear's initial break in period.
Old Aug 6, 2012 | 08:05 PM
easternriderkid
hey guy thanks a lot. can always count on you guys for answers. after the 500 mi mark any special oil any of you would recommend?
Obadabot
Jun 18, 2023 11:31 PM
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
