Car Shudder!
Hi guys last night I was driving home and everything normal until I driving up a hill... my Z was doing fine but then suddenly for a second it shudder and choke and I see either my Engine light or oil light or battery light blink and flash for one time very quickly and then the Z back to normal!~ I couldn't see which light because when my Z shudder that second the light came on for a second then it went off and my Z runs fine! But I remember it is a orange color light so I think it is the engine light but not 100% sure. Anyone has any idea what happend or what caused the problem?
I have replaced a new throttle body a year or 10 months ago! Replaced new camshaft positions sensors and also crank sensor! New Fuel Pump couple months ago! New Coil pads couple months ago! Checked my engine oil and it is normal and on the right amount! Help would be appreciate! Thank you!
are u sure ur rear wheels didnt just slip, maybe a bit of wheel hop caused the shudder? the slip light is orange on the dash and it goes away after ur not slipping anymore. probabaly the case here id think
I was thinking about that too! But I believe I see a light went on on the left gauge and the slip light is at the middle... it just happened too fast scare the Cxxp out of me!
Also there was one time when I stop at traffic light... my gear still in D and I press on the brake! Then my car suddenly shudder and it goes forward a bit while I am pressing the brake! What will caused this problem? I am wondering if a going to break MAF sensor will cause problem like this???
Does it jump forward, or just slowly roll forward?
It is not Jump I think but when I press the brake I feel it roll forward for a second... Or Throttle body??? I got new Throttle body not long ago??? It is a re-manufacture......
It's nothing to do with throttle body either. I honestly wouldn't worry about it.
I had a work truck that would jump forward all the time; there is just a pin that holds the car in park. When you shift out, the pin is pulled. If the car is pushing hard enough on the pin it will "jump" forward.
If it's just rolling, press your brake harder. Every automatic will pull forward when in Drive. Definitely nothing to worry about. If it's not broken, don't try to fix it
EDIT: how far forward does it roll?
Thank you for your reply! I did press the brake and when it happend I felt the car is automatically give a little bit gas like I step on the gas a bit and it jump forward and before this happend the car will suddenly shudder too. But it has not happend since then. Drive my Z for couple days now everything normal... but I am paranoid it will break down and stop in the middle of the freeway. So just in case I would like to find out what happened and get the right part to fix it first before I need to get it tow.... am I being too paranoid? ; )
You'll be fine, just drive it and enjoy it
Thank you very much again. Here's my another questions, if I replaced the NATS Antenna do I need to replaced the BCM and re-program my remote key also? Because my Z will be sometime cannot start at the first fire! It will just keep cranking... I have to switch to stop.. pull the key out and then push it back in to get it fire up! I search on the forum and alot of the experienced Z owner told me it is the NATS Antenna... so I am wondering just replaced the Antenna I am good to go without getting a new BCM and Key re-program?
etkms
Jun 19, 2022 06:30 PM
StreetStandard
Videos
Feb 4, 2016 09:44 AM
BobC-Z
Sep 18, 2015 01:57 PM
