Clutch slave cylinder
Old Aug 29, 2012 | 05:30 AM
Zbandit's Avatar
Zbandit
Default Clutch slave cylinder
How do I check to see if the clutch slave cylinder is bad. My pedal goes to the floor and stays there until pulled up. I think there is a chance it's my actual clutch as the car has 97000miles. I already posted my main problem, was just wondering if there is a way to rule the slave cylinder out.
Caleb
Old Aug 29, 2012 | 08:15 AM
terrasmak's Avatar
Most likely the master , but check the fluid level first. If you see low fluid , check the master and slave for leaks. If not rebuild the master. The rebuild kit is cheap $15 and simple to do , I would also rebuild the slave for the same price , it is even easier. Thee kits are available at www.nissanraceshop.com , talk to Scott
Old Aug 29, 2012 | 08:28 AM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
Does your pedal slam to the floor after a certain point or is there still resistance when you push it in? If it slams to the floor it may be a broken clutch pivot ball, I just went through that.
Old Aug 29, 2012 | 11:02 AM
w210e55's Avatar
w210e55
I hit 100k and just changed both the master and slave clutch cylinder and flushed the fluid, rather do it all then just one at a time and possible pay more later. After that, it's like brand new again.
Old Aug 29, 2012 | 06:13 PM
Zbandit's Avatar
Zbandit
My pedal goes to the floor no resistance and doesn't come back till you pull it up
Old Aug 29, 2012 | 06:15 PM
Zbandit's Avatar
Zbandit
Also the fluid level is fine. It does need a fluid swap but it has never leaked.
Old Aug 29, 2012 | 07:01 PM
oscatipo's Avatar
oscatipo
The slave is gone. Replace, refill, bleed.
Old Aug 30, 2012 | 12:27 AM
pattimang's Avatar
pattimang
Old Aug 30, 2012 | 02:13 PM
ZSpeedPerformance's Avatar
ZSpeedPerformance
Vendor - Former Vendor
What year is your car? Sounds like a worn out master cylinder.
Check this out>
Heavy Duty Wilwood Upgrade
About the same price as the crap OE master.
Old Aug 30, 2012 | 02:26 PM
ksuberk54's Avatar
ksuberk54
Check this out>
someone can't spell cylinder on that site lol
Old Aug 31, 2012 | 06:32 AM
Zbandit's Avatar
Zbandit
It's a 2003 with 97,000miles. The fluid is dark brown so I am gonna do the rebuild and fluid flush. Thanks guys
Old Aug 31, 2012 | 07:21 AM
terrasmak's Avatar
As mentioned , the rebuild kits will cost you $30 , and it is your master that is actually bad.
Old Aug 31, 2012 | 08:03 PM
Zbandit's Avatar
Zbandit
Nope found pieces of friction surface. Aka my stock clutch died
07ZEKE
Aug 23, 2021 09:15 PM
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
