Question about Changing Valve Shims
Old Sep 4, 2012 | 09:34 AM
turbotoast's Avatar
turbotoast
Default Question about Changing Valve Shims
I have an 04 6 speed 350 with 100K on it. It is factory in every way except for an exhaust. It runs beautifully with no hesitation and no loss of power.
It developed a ticking noise, and using a automotive stethoscope I have pretty much pinned it down to coming from the middle to back area of the passenger's side valve cover. It is a very mechanical ticking and stays in line with the RPMs of the motor. The higher the revs the quicker the noise. I can't hear it unless I'm beside a building or outside the car, but it is very distinct when I can hear it. I'm planning on checking valve clearance this weekend, and assuming it's a clearance issue I will have to change the shims.
My question is do you really have to remove the cams to be able to change the shims? The service manual says that is what you have to do, but I have seen tools used like this one
http://www.ebay.com/itm/Nissan-Overh...959#vi-content
to be able to remove the shims and put new ones in. I have seen it done on other cars with a bucket shim setup, but never on a Z.
Thanks ahead of time
So it turns out it was my fuel damper. Confirmed both by holding the line and feeling the line pulse in time with the noise and by putting a automotive stethoscope on the damper itself. Hope this helps people in the future.
Old Sep 4, 2012 | 12:12 PM
jerseystyle's Avatar
jerseystyle
Moved...
issyz
Jul 2, 2017 03:04 PM
allmycarsdie
May 13, 2016 04:38 PM
silverbullet_Z
NA Builds
24
Nov 14, 2015 02:52 AM
rizzla
Sep 29, 2015 03:58 PM
Brantwilliams13
Sep 16, 2015 05:03 AM
