Clutch Pedal, Snap Creek Screech Pop
Old Nov 8, 2012 | 10:58 AM
F34RL355's Avatar
F34RL355
Default Clutch Pedal, Snap Creek Screech Pop
Snap Crackle Pop my clutch pedal does this! as i release the clutch when the clutch pedal is almost fully released it creaks pops etc. i have had the pedal replaced 3 times by the delear and the problem keeps comming back.
anyone ever had this happen to them? anyone know what might be causing this? lubing it all up greasing etc does not do anything, nissan ends up replacing the whole pedal assembly only for it to come back sooner then later
Old Nov 8, 2012 | 11:37 AM
ronn1's Avatar
ronn1
Spray *Liquid Wrench* white lithium grease on the entire pedal mechanism..the area shown below:
I had the same thing...this stuff works wonders.
Old Nov 10, 2012 | 07:09 AM
RJM Performance's Avatar
RJM Performance
Vendor - Former Vendor
Thumbs up
This will solve the problem perminantly and give you all the other benfits too.
It completely eliminates the snap over center spring assembly from the pedal which is the root cause of your snap crackel pop problems.
Have a look: https://my350z.com/forum/engine-and-...l-bracket.html
If your interested shoot me an email or PM to get Canadian pricing. I'm just south of London
Old Nov 10, 2012 | 08:07 AM
binder's Avatar
binder
If they keep lubing the pedal assembly and it doesn't help then there are 2 things that could be happening.
First, the plastic bushings could be damaged so lube will quiet it for a little while but since they are damaged it won't fix anything.
Second, it could be the pivot ball or clutch arm inside the bell housing. If it has a funny wear pattern or damage it would catch when returning.
If you need a new clutch pedal just get the RJM pedal since it makes the clutch 10x better.
Old Nov 14, 2012 | 01:37 PM
F34RL355's Avatar
F34RL355
hey guys thanks for the input, i have greased it idoesnt help, the pivot ball or clutch arm inside the housing hmmm how do they check for this? this is gonna be covered under warranty im on my 3rd pedal so i really dont think its the pedal that causes this :/
Old Nov 15, 2012 | 01:02 PM
binder's Avatar
binder
I would think the clutch arm and pedal are a wear item since it's just a matter of movement that wears it out.
They would have to pull the transmission to get the clutch arm out.
AbrasiveRaysive
Sep 20, 2021 02:29 PM
07ZEKE
Aug 23, 2021 09:15 PM
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
samansharif
Sep 25, 2015 12:31 PM
