I replaced my stock intake with a takedo intake, and when I started my 350z up, it started putting and idled horrible, wat is wrong with my car or wat did I not to right? I plugged in the vaccum hose and the sensor to the new intake.
then you probably have something installed incorrectly. make sure the maf sensor is in all the way, and the hose on the backside of the intake tube is ALL the way on with the hose clamp too. you didn't mess with the throttle body during install did you?
The sensor is in all the way, and No I didnt harm the throttle body. do u think that the sensor could be bad? and like I said I put the stock on back on and it works fine. that is why i am confused
awl ok I will go get that tommorow then... Thanks again for the help.
oh and one last question
You would happen to kno anyone that has a Stock Pearl White Passenger Side Rocker panel ( sideskirt) for sale do you
Did you touch your throttle body plate; maybe cleaned it wiped it down, you know, since you had the tube off. If you did you will have to relearn it and hope you didnt screw it up. I did this and had the same things happen you are describing.
I'm not saying you "harmed" it, but even a slight touch hosed my calibration up.
