Odd vibration from shifter...
Old Nov 20, 2012 | 12:40 AM
sijia10358's Avatar
sijia10358
Default Odd vibration from shifter...
Back ground info,
2008 350z base
58K miles
Manual
After a long track day of extreme driving, I suddenly noticed the shifter would vibrate intensely, but not enough for it to swing side to side. The vibration would intensfy as the rpm increases. Again, not enough vibration for the shifter to swing. This vibration would occur in all gears including neutral. I'm not sure what is causing this vibration and I need your guy's input and opinion. Im guessing either, motor/trans mount, spark plugs, exhaust rattle, clutch disc/ pressure plate/ flywheel, but I can't really pin point exactly....
P.s. the car / vibration does not make any type of noise.
Thanks
Jack
Old Nov 20, 2012 | 04:50 AM
vbanek's Avatar
vbanek
mine does the same thing
Old Nov 20, 2012 | 11:53 AM
bmccann101's Avatar
bmccann101
check your trans mounts, but these cars really all do that.
Old Nov 20, 2012 | 12:06 PM
SQuaLZ's Avatar
SQuaLZ
Agreed. The Z shakes like crazy with no problems but if you were used to that and now it's alot worse I would check your mounts
Old Nov 20, 2012 | 03:09 PM
sijia10358's Avatar
sijia10358
Whats weird is the shifter didnt vibrate before. It only startes after this track day. I went under the car and the mounts look fine :/ I'm hoping its something simple lol
Old Nov 20, 2012 | 03:10 PM
sijia10358's Avatar
sijia10358
Does anyone know a good engine and trans mount?
Old Nov 20, 2012 | 07:18 PM
terrasmak's Avatar
Z1 offers a set, very nice stuff
Old Nov 26, 2012 | 12:38 PM
Itzcashew's Avatar
Itzcashew
when I swapped my diff bushing to a whiteline I felt more vibration in the shifter. then I got a magnaflow x pipe welded in and I feels the vibration alot more from the exhaust pressure. it vibrated with the engine speed. If you put a poly trans bushimg it might vibrate even more.
Old Nov 26, 2012 | 07:02 PM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
Common. Adjust and overcome. Become one with the vibration.
pslamp32
Feb 8, 2017 09:07 AM
Daytona Blue Z in Bo
Feb 9, 2003 04:24 PM
z350z
Dec 16, 2002 05:54 PM
JmanZ
Nov 24, 2002 05:46 PM
