RPM moves with no acceleration
Old Dec 30, 2012 | 04:35 PM
davidcook350Z's Avatar
davidcook350Z
Default RPM moves with no acceleration
I just installed the JWT clutch and light weight flywheel. When I hit the gas in any gear the RPM rises but there is no acceleration. It doesn’t happen all the time. This happened a few times before I replaced the clutch and figured it would go away, but now it is way worse and happens more and more.
I have been reviewing the Forums and most say it’s a clutch issue. This happened with my old clutch and now the new one, so I’m kinda lost.. Any ideas??
Old Dec 30, 2012 | 05:03 PM
R350Zz33's Avatar
R350Zz33
is the flywheel in the right position theres a diif postion for the altima and for the z
Old Dec 30, 2012 | 05:05 PM
davidcook350Z
yea, flywheel is good it idles fine and i never got a check engine light.
Old Dec 30, 2012 | 06:16 PM
bealljk's Avatar
bealljk
Doesnt necessarily mean the clutch is seated right. This could be a problem with either your clutch plate or flywheel not being the right distance from the other.
If you did the work I would take everything apart and look for discrepencies - if a shop did this then take it back and have them fix it.
I don't know if a check engine light would go on with this issue.
Old Dec 30, 2012 | 06:40 PM
SlowNFurious's Avatar
SlowNFurious
Please describe the problem in better detail
Old Dec 30, 2012 | 08:13 PM
AngelsVQ's Avatar
AngelsVQ
you might have to adjust your clutch pedal
Old Dec 31, 2012 | 12:23 PM
davidcook350Z
I cleaned my air flow sensor, it had some water in it and I adjusted my pedal out as far as it would go and I have been driving around all day and I couldn’t repeat the problem.
Thanks for all the replies.
Old Dec 31, 2012 | 02:44 PM
Voboy's Avatar
Voboy
deleted
Old Dec 31, 2012 | 03:12 PM
Spike100's Avatar
Spike100
The solution seems almost too simple!
--Spike
etkms
Jun 19, 2022 06:30 PM
pslamp32
Feb 8, 2017 09:07 AM
Justin100
Nov 29, 2015 03:58 PM
