tail light problems
Old Dec 30, 2012 | 05:43 PM
jwebb350z's Avatar
jwebb350z
Default tail light problems
I'm having a problem with my tail lights after I shut the car off the tail lights and tag lights stay on as well as the radiator fan the only way to turn them off is to turn the key over to acc. I have no idea what could be causing this I just bought the car it is a 2003 touring model, any help would be appreciated
Old Dec 30, 2012 | 08:38 PM
R350Zz33's Avatar
R350Zz33
where u buy it dealer?
Old Dec 30, 2012 | 08:44 PM
jwebb350z's Avatar
jwebb350z
Yes I bought it from a dealer outside of Atlanta with no warranty due to it being a 2003
Old Dec 30, 2012 | 09:11 PM
jwebb350z's Avatar
jwebb350z
Please if anyone has any idea what this could be let me know, I can't keep undoing my battery terminal when I cut my car off
Old Dec 31, 2012 | 09:22 AM
bmccann101's Avatar
bmccann101
no clue, not a common problem.
Id bring it back to the dealership you bought it from and ask for assistance.
Old Jan 1, 2013 | 01:04 PM
terrasmak's Avatar
Sounds like a wrecked car with wire harness damage. Of course, bad repair on the damage.
Old Jan 1, 2013 | 03:18 PM
Spike100's Avatar
Spike100
Hi jwebb350z and welcome to the my350z.com community.
As Terrasmak mentions, it’s a short in the electrical wiring. I wouldn’t go as far as saying you have a “wrecked car with wire harness damage.” Terrasmak knows the Z very well, and I’ll bet he is suspicious because Nissan is known for its bullet-proof wiring.
Electrical problems are often very difficult to solve, but you have good clues since your license plate light and radiator fan motor are tied to the same problem. A good mechanic should be able to drill down to the solution in a short time and provide a fix.
The only thing that might defeat a fairly immediate solution is if a previous owner did some wiring to install an aftermarket whatever.
One thing I always do when solving a short (and I’m suspicious of a previous owner) is removing the trim plate on the door sill and examining the wiring there. If it’s not stock (that will be obvious), the previous owner may have butchered some of the car’s wiring. That means you’re on the “hunt.”
--Spike
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
