Oil pressure gauge showing at 120psi on idle. ANY HELP?
Hello,
I'm hoping that someone out there will be able to help me out with this problem that just occurred with my 350z. It's a 2003 with approximately 193k miles on it.
Anyway, when I turn the key, oil pressure gauge reads at 80-90 psi. When I turn on the car, the oil pressure jumps up to 120 psi. When I start driving (cruising) the oil pressure will jump up, way over 120 psi.
I had just got an oil change about a week ago with Mobil 1, 10W-30 full synthetic, which I have been using for years now. Someone please HELP! It would be greatly appreciated.
+1 to the sending unit…it's the sensor that's attached to the oil pan, sorta near the drain plug…
Mine went out and caused similar issues...I can't remember the torque spec but be very careful when torquing that in…if you break it you'll have to pull the engine and replace the lower half of the block. IIRC, the sensor was like $60.
hmm... lets see.... it seems your sending unit sensor has malfunctioned. You will need a new one for around $80 or so. Installation is not difficult but be careful when torquing the sensor, dont break it. The sensor can be found on the oil pan near the drain plug. I hope this helps
@ vladbeb and Zatara, I got a stright pipe on this beast.
To the rest of you who replied, thank you!! Thank God for this forum!
+1 on Zatara's question. What is the torque spec for the oil sensor?
I've been meaning to replace mine too. It will max out every once in a while then go back to normal.
I'm assuming that changing it out will drain a bit of oil? I'm just wondering if I should just wait until the next oil change so I don't spill oil everywhere trying to replace the sensor.
