Check Engine Error P0345
I was driving home from work yeasterday and my engine just died while driving. The check engine light, Slip & TCP light all light up and the car wouldn't turn over till the 3rd try. I stopped by auto zone and had them do a printout of the code P0345.
It says it could be:
1: Open or short circuit condition
2: Poor electrical connection
3: Weak Battery condition
4: Faulty CMP
I charged the battery overnight when I got home & it seemed to work till my gf took the car to the store & the some thing happened to her. Luckily I have a battery pack in my car I told her how to connect it to jump the car. she said she could smell something electrical burning but who knows.
Its a 2005 350z with 100k miles on it & just had the oil changed & have a full tank of gas if that is relevant.
Any ideas what I should try next?
I have a 15 mile drive to work very early in morning & don't want it to die on me.
4: Faulty CMP
Most likely culprit is the battery. Pull it and take it in to be tested. Simply charging it may mask the problem, but won't solve it. I notice the batteries in my Z seem to last about 4-5 years before they simply refuse to hold a charge. Might also want to check the alternator function to make certain it's not malfunctioning and overcharging the battery.
just had auto zone do a battery check & they said it looks good. They said it could be the camshaft sensor bank 2 but didn't have a replacement in stock. I sprayed some connector spray on the sensors connector & seems to be starting perfectly. hopefully it will get my to work before I can get a replacement...
Hate to say it, but just throwing parts at a problem isn't such a great DIY tactic. It could be a bad connector, a ground that's corroded or other electrical issue. This is where a sharp tech with a plan to troubleshoot individual problems is far ahead of the rest of us. For someone who counts on their Z as a DD, it may actually be cheaper to go this route vs. throwing parts at it and hoping.
liqalu04
Jan 2, 2022 12:58 PM
