07 350z brake bleeding
Old Mar 8, 2013 | 02:53 PM
K9Zdriver's Avatar
K9Zdriver
Default 07 350z brake bleeding
Why is there a second brake container on the left? Am I supposed to change the fluid in the smaller container? I'm doing a complete brake bleed. Thanks for your help.
Old Mar 8, 2013 | 03:15 PM
DarkZ03's Avatar
DarkZ03
clutch fluid.
Old Mar 8, 2013 | 04:21 PM
myork's Avatar
myork
Take it to a professional before you kill yourself or worse, some innocent pedestrian crossing the street.
Brakes aren't something to mess around with if you don't know what you're doing.
And if you don't know the difference between the brake master and the clutch master, you dont know what you are doing.
Old Mar 8, 2013 | 04:41 PM
michaelm5's Avatar
michaelm5
Sometimes ya get intense criticim when you post on forums. if you do know how to properly bleed brakes then get a Nissan service manual so you can see all the systems. If you have not bled brakes before seek help.
Old Mar 8, 2013 | 05:00 PM
K9Zdriver's Avatar
K9Zdriver
I've bled brakes before but not clutch fluid. The clutch cap says to use fluid similar to the brake fluid, which threw me off. I just bled the brakes using the motive bleeder. Is there a link to clutch fluid change. The fluid looks a bit brown. Any help on the clutch fluid change would be greatly appreciated.
Old Mar 8, 2013 | 05:21 PM
thekinn's Avatar
thekinn
here.. read this. if you don't have an answer at the end.. pay someone
oops, not this thread - but you will learn a lot from it..
https://my350z.com/forum/maintenance...ed-issues.html
try this one- and/or like they said - read the service manual. which is also found on this site in a search -
https://my350z.com/forum/forced-indu...-pressure.html
Chris350z03
Oct 8, 2023 07:19 PM
JjL
East Canada
Jun 12, 2019 03:04 AM
Vigman
Nov 17, 2015 04:34 AM
hardkicks
Sep 20, 2015 12:28 PM
