Core Support Replacement
Old Mar 20, 2013 | 05:09 PM
Brehmster1's Avatar
Brehmster1
Default Core Support Replacement
Just purchased a 2006 Z, listed to have 10k (lets hope its legit) actual miles from insurance with what appears to be minor front damage and was wondering if anyone has replaced the radiator core support? Any crazy obstacles to watch out for when replacing?
Any recommended places to purchase parts?
Any info much appreciated
Attached Thumbnails Core Support Replacement-photo-42-.jpg   Core Support Replacement-photo-39-.jpg   Core Support Replacement-photo-41-.jpg   Core Support Replacement-photo-40-.jpg
Old Mar 20, 2013 | 05:24 PM
3fidzhr's Avatar
3fidzhr
It's rather easy and straight forward.
Old Mar 20, 2013 | 07:00 PM
terrasmak's Avatar
Simple, very simple. I had to replace mine over the summer. On a scale of 1-10 , and a 10 being a motor build. The core support would be a 2
Old Mar 20, 2013 | 07:34 PM
drvqz33's Avatar
drvqz33
Very simple fix.
For used parts check out slidegood.com
For new, I'd check courtesyparts.com
Old Mar 20, 2013 | 07:48 PM
Brehmster1's Avatar
Brehmster1
Thanks for the replies...glad to know it is not to big of deal. I have not actually looked at the car in person yet, just trying to prepare myself for whats coming and locate and price out the core support and other parts I will need.
Old Mar 20, 2013 | 08:50 PM
myork's Avatar
myork
Take a real close look at it in person - notice that the battery cover doesn't sit right. Could just be the fender shifted, or the frame could be tweaked a little.
Don't be suprised if that seemingly little damage winds up to be a few thousand - my dd looked better than that yet cost $4500 to fix.
Old Mar 20, 2013 | 09:04 PM
Brehmster1's Avatar
Brehmster1
Yikes...let hope not cuz I already bought it. Hoping the low mileage will help me come out ahead, but who knows. Taking a chance and hoping it is not to bad...picked it up for $5000 but will have close to $5800 in it when it lands in my driveway.
Old Mar 20, 2013 | 09:42 PM
K51's Avatar
K51
Looks like a good buy for $5800. My '08 had quite a bit less visible damage from a minor front side-swipe impact last Fall, and the bill was ~$7K. Much of it was the airbag/seatbelt stuff, though. Basically, the bumper cover got ripped off and the core support had a tiny crack, but unfortunately the airbag sensor just barely got tapped and the driver's bag blew and both seatbelts retracted and locked - car wasn't even moving. Even both the fenders and headlights were undamaged, so it really did look like a very minor impact.
Old Mar 20, 2013 | 11:17 PM
Voboy's Avatar
Voboy
I wouldn't put all my bets on a battery cover and surrounding - its all plastic. it looks like its not put back right. damage looks pretty minor.. air bags didnt even go off. doubt there's any frame damage then.
core support is pretty simple. if i remember correctly you can remove and reinstall it with the radiator and fans attached.
Old Mar 21, 2013 | 03:32 AM
Brehmster1's Avatar
Brehmster1
It is just another form of gambling I guess...
I tend to lean towards light damage as Voboy pointed out the bags did not pop which tells me it probably was not to bad. Auction folks probably had the battery cover off to jump but still the possibility is there...my experience has always been that there is always more damage than you think so bid appropriately. Still trying to figure out why the driver seat is covered???
I do like like the fact the core support can be replaced without welding and as you guys pointed out pretty simple...if this goes well I might need to start buying these cars more often.
Old Mar 21, 2013 | 05:15 AM
350TX's Avatar
350TX
Awesome find! I just completed a motor swap on my '04 w/ 209K miles for a lower mileage unit. In the process of doing the swap I removed the core support and I was surprised how easy it was. Not necessarily straight forward since you have the radiator, a/c condenser, power steering cooler, windshield wiper fluid reservoir, and electrical harness attached. It may seem tedious but not complicated. Just have zip ties handy to help hang/support components (i.e. a/c condenser). The part that held me up was the disconnecting the lines to/from the power steering cooler. Make sure you have something to catch the fluid, I used a cheep-o plastic bucket.
When I removed the core support, I still had the headlights and the subframe on (the part attaching the core support to the upper wheel well structure). I'm not sure if my approach would be ideal for you since you are replacing the core support and I was just trying to remove it as a much as a modular unit...
Old Mar 21, 2013 | 05:50 AM
Brehmster1's Avatar
Brehmster1
Thanks, looks like some good advice.
Old Mar 21, 2013 | 04:40 PM
WeightLimit's Avatar
WeightLimit
I'd recommend you tear it down and make a list of the parts that need replaced before you start buying everything unless its on the exterior. Keep everything you take apart separate. Place every nut and bolt in bags and label it to make reassembly easier.
Radiator supports around $500 from a dealer. I'm not sure if they sell it in sections or not, probably do.
I use this site from time to time for used parts:
http://www.car-part.com
Search craigslist and here as well.
350z82
Oct 1, 2015 06:25 PM
SharX59
Sep 30, 2015 10:54 AM
