Gouged my gas tank!!! :(
Old Apr 15, 2013 | 10:38 PM
Zee-u-later's Avatar
Zee-u-later
Thanks all for the replies... And yes just ordered a gas tank... Which i know is going to be a pain to install
Old Apr 16, 2013 | 05:41 AM
theoutlawchris's Avatar
theoutlawchris
I've never done it on my 350 but on my old my fox body mustang it was just two bolts and your done, if you trying to figure out how to get the gas out try siphoning it.
Old Apr 16, 2013 | 05:42 AM
FWM69's Avatar
FWM69
Set the car on flames and roll it off a cliff.
Old Apr 16, 2013 | 07:11 AM
kingdom's Avatar
kingdom
Originally Posted by Zee-u-later
The question is... How do i drain half a tank?
use the hole you punched in it. or buy a siphon from your local hardware or automotive store.
On the bright side at least you didn't get crushed by your car.
Old Apr 16, 2013 | 07:45 AM
Syner's Avatar
Syner
You could try punching a hole in the tank.
Not sure if you are mechanically inclined, but don't listen to any of the bad advice here. Replace your gas tank.
Old Apr 16, 2013 | 07:50 AM
redline06's Avatar
redline06
seriously fawk what everyone one here is saying just replace the gas tank!
Old Apr 16, 2013 | 08:26 AM
iideadeyeii's Avatar
iideadeyeii
Seriously. Just buy this, put it in(That's what she said) and you're done.
http://www.nissanpartszone.com/parts...202-ce800.html
Old Apr 16, 2013 | 10:32 AM
SQuaLZ's Avatar
SQuaLZ
This and then don't ever work on cars again. You're lucky you're still alive. Either the jack stand failed or you put it improperly, and I am going to assume the latter.
Old Apr 17, 2013 | 10:24 AM
The_Assassin's Avatar
The_Assassin
Do not believe any of these guys. I say ditch the gas tank( stage 2 weight reduction) and go full solar powered. Thank me later
Old Apr 17, 2013 | 11:20 AM
TheDangerZone's Avatar
TheDangerZone
is the gas tank half empty or half full?
Old Apr 17, 2013 | 12:49 PM
Zee-u-later
Well i just said to hell with it and made the gouge bigger and just drained the 8 gallons of gas from it... Fun stuff i tell ya!
Old Apr 17, 2013 | 01:37 PM
Junkster's Avatar
Junkster
I HIGHLY recomend using the replace the gas tank method.
Old Apr 17, 2013 | 02:08 PM
KornerCarver's Avatar
KornerCarver
If I remember correctly, the entire rear subframe has to be removed to gain access to the gas tank. When the gas hose recall was done several years ago, I'm pretty sure the dealer removed the rear subframe. Do you have the proper tools to raise the car to accomplish that task?
Old Apr 17, 2013 | 04:31 PM
Spike100's Avatar
Spike100
So, i was raising my Z to get another jack stand onto the drivers side and one of my jacks slipped and got caught on my gas tank. Smelt gas and low and behold theres a gash on the tank. What would be the best possible solution for this stupid idiotic mistake of mine?
Old Apr 17, 2013 | 05:07 PM
KornerCarver
And that is why I asked the question. It would seem replacing the gas tank is a major task and I would think some kind of lift would be required.
Old Apr 17, 2013 | 05:22 PM
Spike100's Avatar
Spike100
Of course you are correct… Remember that the OP is the guy whose car fell from some jack stands. I hardly think he has some sophisticated lift equipment.
I’m not flaming or saying “duh.” I am simply pointing out the obvious.
--Spike
Old Apr 19, 2013 | 07:22 AM
abarclay's Avatar
abarclay
OP, I'm happy you got all these great recommendations. I was worried that no one would know how to help and your thread would...tank.
Old Apr 19, 2013 | 10:11 AM
  #38
SQuaLZ's Avatar
SQuaLZ
Agreed. I helped my buddy change the tank on his Chevy pickup and damn that thing was a pain. It took forver, plus we broke a hose when dropping out the old one (forgot to disconnect the hose that runs to the gas door)
I would figure that changing a gas tank on a pickup would be much easier than on a sports car, mainly due to room and ground clearance.
I recommend you go to a professional.
liqalu04
Jan 2, 2022 12:58 PM
350Z_Al
Oct 29, 2020 07:44 PM
CJs_Z33
Sep 18, 2015 12:06 PM
