loud sound from the back of my 350z
So driving home today, doing 50..60 kph (30..40 mph) I heard a loud sound coming from the back of the car very low, as if something broke or fell off. Maybe a pop sound, but a deep pop sound. I don't think it was a backfire, but I don't know the car well enough to make that call. EDIT: As soon as I heard the sound I checked the road behind me for parts, and there was nothing. Don't laugh, I've had a large section of an exhaust system fall right off in a vehicle before!
I pulled over quick and looked underneath and saw nothing out of the ordinary. Nothing looked loose or hanging. The exhaust system looked fine. It also sounded fine. I went over some bumps and accelerated a bit and everything feel and sounded solid.
I'm having my mechanic check it out tomorrow. Just thought I'd ask for some insight. I know I've given barely any info, but that's all I have for now. (I wish I had recorded it!)
UPDATE: I had it parked outside for about an hour, if that, and there was a huge puddle underneath it. I moved the car out of the way and it looked and smelled like oil. It was thick brown. The oil I use is 5W-40 full synthetic, Irving brand. It's supposedly high end oil. Now, I'm no expert, maybe it was another fluid. I'm not sure. My mechanic is going to look at the car tomorrow, and he should have a nice puddle underneath it to look at as it'll be parked there all night. Just drove it in.
I'll update this thread in case it happens to anyone else.
SQuaLZ, when your differential blew, could you tell other than the sound? I couldn't feel anything was different. The only evidence something had happened was the deep pop sound, which sounded like something fell off my car deep in the back, and then the puddle. If the diff blew, would it have leaked out its oil? Would it be thick brown? I'm thinking, yes.
terrasmak, the puddle was in the center. I was walking up to the car directly from the side and it wasn't hidden by any of the wheels, front or back. I remember thinking it was a bit far back to be oil, but I'm not sure where the oil would have leaked out.
UPDATE: The mechanic checked all the fluids, including engine oil and differential oil, and they were all fine. Plus, no oil puddle under the car from having it parked there for 12 hours. In comparison, the puddle I saw would have been created in under an hour the day before, which was deep enough to stick half my finger tip into. That means we should have measured low oil somewhere had it been mine.
So... looks like it's just a coincidence and I parked over someone else's puddle of oil, and the sound must have been something hard hitting the bottom of the car.
I still feel like something's up, as I was driving so slow for such a "something just broke" sound to happen. I'll have to keep an eye on more fluid leaking just to be sure.
Mixed emotions!
Mixed emotions!
Is it possible the transmission did leak, enough for a large puddle, and then stop and still have enough fluid left for the mechanics to find nothing wrong the next day?
I'll have to pay attention to the transmission. Maybe if it's becomes hard to shift or something.
Honestly, it sounds like you need a new mechanic. Just get under the car and look yourself.
It should be completely dry around the drain/filler plugs. Don't wait for a problem to become evident, it only takes a couple minutes to check it yourself.
The fill plug is higher and on the passenger side. If that went out and you were sitting with the passenger side slightly lower (parked on a normal road), there is a chance that it could have leaked. When you level out, the oil won't leak.
Ok, so exactly how do I check this myself?
Maybe when I had it parked at the garage and also in my own parking lot I was too even for it to spill, but where I had it parked was at my girlfriend's place for the hour where it may have leaked, and the road could have been slanted a bit. I'll have to check.
So, get under the car and how do I locate the drain/filler plugs? Is there any threads with pics or vids to help me out? I'll try my best with what you gave me already. (The fill plug is high and on the passenger side.)
EDIT: I'm putting up on a lift tomorrow and I'm going to specifically check this out. Thanks for the help. Much appreciated.
There should be absolutely NO oil around these plugs. It will be easy to tell if anything was leaking.
Update: I took it to another mechanic today and watched them check the transmission oil, and it was filled. They stuck their finger in there basically and there was plenty. There was no signs of leaking oil from either the transmission or the engine, so it looks like all is well.
Thanks so much for the help.
m_0g
Jun 3, 2021 10:05 AM
AbyteZero
Sep 22, 2015 09:17 AM
