Brake Lights not working
Old May 25, 2013 | 06:34 PM
Za33cK's Avatar
Za33cK
Default Brake Lights not working
Ive removed the fuses that i thought were the problem under the steering column, they were all good, no bad fuses, i removed the taillight and replaced the bulb with a new one, its not the bulb, i even put a multimeter to the socket where the bulb connects to and it is receiving current, i also checked the fuse box in the engine bay, and the fuse which i thought it would be was not blown either, today i bought the brake light switch and replaced that to, what is going on?? the brake light switch i replaced was the one on top of the other switch, it has the white plug connector, so if its not that one i guess that is my problem. here are some pictures i took, im decently mechanically inclined, so im trying to do all this myself, but if it comes down to it, i might have to pay a shop to fix it
Attached Thumbnails Brake Lights not working-imag0025.jpg   Brake Lights not working-imag0026.jpg   Brake Lights not working-imag0031.jpg   Brake Lights not working-imag0029.jpg   Brake Lights not working-imag0030.jpg
Old May 26, 2013 | 01:16 PM
go-part's Avatar
go-part
Vendor - Former Vendor
http://www.*********.com/forums/123-...-problems.html
Old Jun 30, 2013 | 10:41 AM
upx's Avatar
upx
Hi, did you ever get this fixed ?
If you're sure you're getting the right amount of power (volts, amps, watts -- with the brake pedal depressed) at the sockets, then is it possible that your new bulb is bad too ?
I assume that you're talking about stop lamps and not tail lamps, because there seems to be another fuse for that on the Side of the battery.
BTW, thanks for the 350z fuse box pictures -- couldn't find these anywhere on the net. What year is your Z ?
OT: Just for the future benefit of this forum and other net users, here's a pic of the 2004 Nissan 350z fuse box (with cover layout) that's in front of the battery;
https://i.imgur.com/VQhh1DWl.jpg
Miguel Albanez
Oct 17, 2022 10:13 AM
dboyzalter
North East Marketplace
15
May 6, 2018 09:41 AM
Vigman
Nov 17, 2015 04:34 AM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
samansharif
Sep 25, 2015 12:31 PM
