stiff steering
Old Jun 9, 2013 | 05:39 PM
tw8715's Avatar
tw8715
Default stiff steering
so my steering wheel turn with more effort then usual.
i thought it was the pump and replaced it, but has the same effects.
so im thinking its the rack and pinion...
any DIY to replace this? is it at pretty easy job?
Old Jun 9, 2013 | 05:49 PM
dcains's Avatar
dcains
Check your tire pressures?
Old Jun 9, 2013 | 07:12 PM
tw8715's Avatar
tw8715
tires pressure is good~~~ anything else it could be?
Old Jun 9, 2013 | 09:37 PM
350Zdj's Avatar
350Zdj
Steering pressure sensor. Have a look physically and / or scan the ecu for error.
Mine broke lol.
Old Jun 10, 2013 | 10:55 AM
tw8715's Avatar
tw8715
Where is that located? And how do I know it's faulty by looking at it? I'm not throwing any codes right now
Old Jun 11, 2013 | 01:55 AM
jomamahama's Avatar
jomamahama
you didn't recently change to wider tires did you?
Old Jun 11, 2013 | 11:31 AM
tw8715's Avatar
tw8715
No I had 255/285 from the beginning
Old Jun 11, 2013 | 11:56 AM
350Zdj's Avatar
350Zdj
I'm trying to remember where exactly but I can't. It should be right under the center of the engine I think. It's just some connectors. Maybe it's loose / dirty.
Old Jun 11, 2013 | 06:43 PM
tw8715's Avatar
tw8715
i thought this only assist power steering at low speed? like in parking lots and so on
Old Jun 16, 2013 | 03:33 AM
tw8715's Avatar
tw8715
could it be the steering shaft? iv been searching around and do we have a u-joint?
Old Jun 16, 2013 | 05:08 AM
350Zdj's Avatar
350Zdj
I think that's true. If it's not functioning, then your steering will be stiff at low speed.
Old Jun 16, 2013 | 12:15 PM
kyle22's Avatar
kyle22
Maybe your power steering fluid is low? What year is your Z and how many miles are on it?
Old Jun 16, 2013 | 09:15 PM
tw8715's Avatar
tw8715
no steering fluid is new and good. im thinking it might be this sensor. but im not getting a code for it.
Old Oct 20, 2014 | 05:50 PM
MaN0Lo's Avatar
MaN0Lo
Digging in the graveyard here lol did you ever fixed this issue? I'm having issues with steering now. I turn (happens both directions) and at first is normal but then gets hard at certain point. Also prior to this issue (while making a turn) half way thru the turn I let the steering reposition itself but now it barely wants to reposition itself. I have been told by one shop that my rack and pinion is bad then I had another wanting to play the game of Which part is it? told me to do the power steering pump first cause my fluid is fried and most likely its cause of a bad pump but then said and if that doesn't fix the issue then is your rack and pinion. Does anyone here know a trustworthy shop or local mechanic that know this cars well? I'm located in Orlando,FL.
aarrgghh
May 1, 2022 11:04 AM
HoBrahYouStink
Jun 24, 2016 10:58 PM
Depravity
Oct 1, 2015 04:49 PM
dragon11689
Sep 7, 2015 02:47 PM
