Burning smell under acceleration
Old Jun 10, 2013 | 11:34 PM
tw8715's Avatar
tw8715
Default Burning smell under acceleration
When I pull hard in any gear I get a burning smell. Stock everything. I also see a little smoke out from the rear.
Any ideas?
Old Jun 11, 2013 | 01:48 AM
Simon da Silva's Avatar
Simon da Silva
hmm.. fried piston ring maybe?
Check the compression in the different pistons or keep an eye on your oil consumption
Old Jun 11, 2013 | 03:01 AM
Wakatow1369's Avatar
Wakatow1369
Definitely sounds like the rings are bad.
Old Jun 11, 2013 | 09:10 AM
Bret86944's Avatar
Bret86944
How bad is it? Because a little of this is normal in any car.
**What year and mileage is on your car?
Old Jun 11, 2013 | 11:32 AM
tw8715's Avatar
tw8715
It's not that bad but concerning. I've never had low oil before~
Old Jun 11, 2013 | 11:47 AM
dkmura's Avatar
dkmura
General & DIY Moderator
It could also be a failing clutch disc, particularly if it's an acrid odor coming at each shift.
OP- it would really help to know what year and mileage is on your Z.
Old Jun 11, 2013 | 06:46 PM
tw8715's Avatar
tw8715
2004 with 110k miles on it.
i changed out the clutch and flywheel to the JWT setup when my car hit 60k
dosnt smell like a buring clutch?? also i see a little smoke so i dont think its the clutch
i do have 2 codes causing the check engine light to be on.
P1284
P1273
thought it was the front o2 sensors.. replaced them and the lights back on again with the same codes
apex locator
Jul 23, 2021 02:27 AM
3vilbunny
Jul 18, 2017 05:10 PM
pslamp32
Feb 8, 2017 09:07 AM
ti837
Sep 22, 2015 07:46 AM
smithmt3
Sep 11, 2015 08:25 PM
