My exhaust is making a fluttering sound...HELP!
Old Jul 10, 2013 | 05:25 AM
JaimeNismo's Avatar
JaimeNismo
Default My exhaust is making a fluttering sound...HELP!
My exhaust is starting to make a fluttering sound but its only coming from the left side? More pressure comes out from the left side also. Do you know what it might could be? The cats?
Old Jul 10, 2013 | 05:28 AM
PerfZ's Avatar
PerfZ
Probably. Year, mileage, and stock or aftermarket? Details help when doing internet diagnoses'.
Old Jul 10, 2013 | 06:17 AM
oldschool350z's Avatar
oldschool350z
I don't think it would be the cats if it's just one side of the muffler. The stock setup is not a true dual and it's just one pipe from the cat.
Old Jul 10, 2013 | 07:34 AM
JaimeNismo's Avatar
JaimeNismo
2003, 160,009, aftermarket exhaust. But before I changed the exhaust it was the same thing wiyh the stock exhaust.
sk8r776's Avatar
sk8r776
Would probably get a better answer if you posted a video. or even a sound clip. i noticed with the stock exhaust the driver side tip always has more exhaust coming out of it.
Need a little better description too, is it all the time this sound happens? is it only on decel? around a certain rpm range. all these will help get a more accurate answer.
Old Jul 10, 2013 | 08:23 AM
DavesZ#3's Avatar
DavesZ#3
"fluttering" sound could be an air leak. if you've changed exhausts and it still does it, probably where the cats meet the Y-pipe.
Old Jul 10, 2013 | 09:39 AM
phreaktor's Avatar
phreaktor
Design Engineer
^This
Old Jul 10, 2013 | 09:40 AM
phreaktor's Avatar
phreaktor
Design Engineer
http://www.ebay.com/itm/200851763152...84.m1439.l2649 Or it could be a crack..
Old Jul 10, 2013 | 09:59 AM
sk8r776's Avatar
sk8r776
If your still single out i would check the flex joints. both mine failed at the same time and it sounded like a rattle. But turned out they sucked air in causing the noise on decel. if a cat was bad you would hear rattling as well because the stuff inside is broken up.
Old Jul 10, 2013 | 11:07 AM
Z33Garage's Avatar
Z33Garage
Maybe someone shoved a potato in one of the pipes
Justin100
Nov 29, 2015 03:58 PM
nanotech
Oct 2, 2015 05:02 AM
Li1ag
Sep 28, 2015 02:07 PM
