dipping idle
Old Jul 10, 2013 | 10:46 PM
tw8715's Avatar
tw8715
Default dipping idle
when i rev in neuteral and the rev is coming back down it dips to 0 and car shutters and almost turns off.
i checked everything dont know what up
i recently change valve covers and spark plugs. and cleaned the fuel injectors too.
i also had the code p0113 - intake air temp sensor 1 circuit high input
but i cleared the code and hasnt came back for about 50 miles
i cant find any vaccumn leaks or anything
ALSO car barely starts sometimes and even shut off once.
Old Jul 11, 2013 | 03:08 PM
zakmartin's Avatar
zakmartin
http://www.obd-codes.com/p0113
You don't seriously think that simply clearing a code is going to make the problem go away, do you?
Old Jul 12, 2013 | 01:33 AM
tw8715's Avatar
tw8715
The code hasn't came back yet.
Does the car have to learn how much fuel goes in after cleaning injectors?
Old Jul 12, 2013 | 03:59 AM
tw8715's Avatar
tw8715
here is a video.. you can hear the car trying to stall
http://www.youtube.com/watch?v=QqAi0...ature=youtu.be
Old Jul 12, 2013 | 11:42 AM
oldschool350z's Avatar
oldschool350z
Clearing the code will do nothing.
Does it also go down when just at idle?
Old Jul 12, 2013 | 01:19 PM
tw8715's Avatar
tw8715
Unhappy
No it dosnt. Only when coming down from rev
Old Jul 13, 2013 | 01:55 AM
tw8715's Avatar
tw8715
Bump! Any one?
The code has completely gone away I think. Drove about 200miles or so and code clean.
But this idle dipping on rpm downfall or clutch depress is no good
Having hard time starting sometimes. It stumbles and then catches up and idles normal
liqalu04
Jan 2, 2022 12:58 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
05UltraYellow
Sep 24, 2015 05:41 AM
Darkspy
Sep 7, 2015 09:09 PM
