burning smell engine, when being pushed-new opinion
Old Jul 22, 2013 | 05:40 PM
knillsoccer13's Avatar
knillsoccer13
Default burning smell engine, when being pushed-new opinion
i didn't want to bump any threads because i have noticed a different scenario than many explain...
i don't smell anything when i am shifting at high rpms, but i do notice the smell when the gas is being pushed harder than the rpms are willing to accelerate. Example: being in third/fourth at 2k rpms and pushing it all the way to the floor(i wouldn't do it to this degree) But, the rpms can't simply just jump up- and this is where I experience the smell- when you pass this "threshold" of gas to acceleration capability. But what is this burning smell? my dad has been a mechanic for 40+ years and says he has smelt it a few times and that it definitely is not clutch burning. i have an 06, 40k.. also if i put the ac on recirculate i don't smell it in the car(with the windows up) so does this change anyones mind on what could be the culprit?
the smell isn't a gas or oil smell either
-- this is my scenario because i have tested it a few(3-5) times and it is reproduced
Old Jul 23, 2013 | 09:58 AM
oldschool350z's Avatar
oldschool350z
Does your 2006 consume oil at all? The rev up engine is known for that and if you're low it could be the issue..
From time to time I've had a similar type of smell in my cars but really only when accelerated fast. Sometimes when someone passes me and steps on the gas I smell something like gas from their car. Ex) I'm driving in the slow lane and a camero passes me and guns it. The smell can be smelt as I'm driving behind them for a couple seconds .
The smell of a burning clutch is strong and distinct. is your clutch slipping at all?
Old Jul 23, 2013 | 05:26 PM
knillsoccer13
No, the clutch isn't slipping(to my knowledge- my dad said clutch is fine) and i am not consuming oil either... Though i do know this is an issue in these motors, and i hope i never have that issue, but i do check my oil monthly. Also, i understand your example, but this is more of a burnt plastic type of smell, but still not completely
The only thing i haven't tried(after researching) is looking at the exhaust for something burning on it, but since it is definitely coming from the engine bay i do not think that will be my problem. We have car lifts though so i will look sometime this week/end
Old Jul 24, 2013 | 12:07 PM
zakmartin's Avatar
zakmartin
First, change your MTF - if you haven't already, then it probably needs changing anyway. Smell the old stuff before you recycle it. Does it smell burnt? The weak point in your situation is the clutch, so logic dictates that your mechanic is wrong. If you really push your car when you drive it, as you state in your post, then there's a strong possibility that your factory clutch has started to crap out.
Old Jul 24, 2013 | 05:39 PM
knillsoccer13
40+ years of owning a successful business, like he wouldn't know about clutches and i dont necessarily push it. maybe once every other week... when i am having fun with some buddies of mine. I will take your advice though and check the fluid. I am pretty sure i had it changed around a year ago, but could be mistaken.
Old Jul 24, 2013 | 05:49 PM
mcarther101's Avatar
mcarther101
I don't know honestly, but from what you're telling me - I advise you not to drive in that manner. You're putting unnecessary stress on the clutch, probably going to wear it out faster that way. If you want the "gas to match the acceleration" or what-ever you called it, downshift.
When my clutch was going out a few thousand miles ago, I noticed it would slip if I "gassed it at 2k RPM," but so long as I downshifted, or applied the gas very gradually, the clutch would hold. Use those gears! Just food for thought.
Old Jul 24, 2013 | 08:31 PM
knillsoccer13
I do! Thanks for the advice though! i only did this trying to figure out the smell. I didn't know that put strain on the clutch, i thought once it was in gear the clutch was no longer engaged so it couldnt affect it in such a way. the only time i hit 2k is accelerating through first
and tips on how to notice a "slip" in the clutch? i don't have bouncing rpms ever or it pop out of gear or anything
Old Jul 25, 2013 | 12:47 PM
zakmartin's Avatar
zakmartin
Yes, that's exactly what I'm saying.
Old Jul 25, 2013 | 01:01 PM
Syner's Avatar
Syner
I thought your mechanic had 40+ years of owning a successful shop? Shouldn't he have "tips"
Old Jul 25, 2013 | 01:10 PM
oldschool350z
I can tell you how to test for a slipping clutch. In 2nd or 3rd gear be at 2k rpm, then accelerate i.e. you're foot hard on the accelerator.
If you see only the rpm's go up and not the speed your clutch is shot.
Old Jul 25, 2013 | 03:34 PM
knillsoccer13
nope. he said it's nothing to worry about. i just don't like it. dont act like your so smart, you dont know the problem either.
Old Jul 25, 2013 | 03:49 PM
knillsoccer13
http://www.youtube.com/watch?v=9I9Qvo-b1jU
mine definitely does not do that
Old Jul 25, 2013 | 03:52 PM
knillsoccer13
so clutch is good...any ideas on what else the smell could be? is there something that heats up a lot when you pump a lot of gas into the engine(minus the engine itself obviously) when there is this type of load- explained in the op
ps i do talk to him, but he is convinced it is something i should not worry about and doesn't say a lot about the topic except not to worry. there is really no way to explore this issue since it only happens on the road- so taking it to another mechanic would be somewhat pointless
Old Jul 26, 2013 | 04:32 AM
oldschool350z
If there are no actual problems, leaks or oil issues I wouldn't worry about it.
Old Jul 26, 2013 | 06:47 AM
Syner's Avatar
Syner
Apparently I'm as smart as a 40+ year mechanic, because he doesn't know the "problem" either. Your words, not mine.
Don't fix things that aren't broken.
Old Jul 26, 2013 | 08:23 AM
06Gcoupin's Avatar
06Gcoupin
VQ is just a smelly engine.
After just 10 minutes of hard runs, 120+mph and such....i come back home, park it, and she just stinks....
Its very similar to p^ssy bro....after you beat it up for an hour or so, its gonna smell a bit bro
liqalu04
Jan 2, 2022 12:58 PM
apex locator
Jul 23, 2021 02:27 AM
3vilbunny
Jul 18, 2017 05:10 PM
Fixxxercask
Nov 9, 2015 11:10 AM
samansharif
Sep 25, 2015 12:31 PM
