Need HELP asap trasmission problems
Old Aug 15, 2013 | 05:48 PM
superman1128's Avatar
superman1128
Default Need HELP asap trasmission problems
so I installed a new clutch and when I put everything back and hit the clutch it stayed stuck to the ground after pushing it 1/4 of the way it just snapped down. so I came on here and searched and the most common thing was air in the lines bled the lines still having the same problem so I purchased a new slave cylinder installed it bled the lines again still having the same problem not sure what to do any help would be appreciated
Old Aug 15, 2013 | 07:00 PM
Italianjoe1's Avatar
Italianjoe1
You sure it's bleeding correctly? Once it has pressure building up it will push the pedal back up, the snapping down is normal at this point.
It's possible the master cyl is bad but it sounds like air in the system still to me.
Old Aug 15, 2013 | 07:32 PM
superman1128
Is there a different way of bleeding the lines? I took a clear tube put it on the clutch release valve nipple, had a friend pump the clutch 5 times, opened the release valve, counted one second, closed it and repeated this step maybe 10 times and still nothing. There doesn't seem to be air in the lines from what I can tell, I don't see air bubbles in the tube when I open the valve.
your in south florida want to come help LMAO
Old Aug 15, 2013 | 07:41 PM
SparkleCityHop's Avatar
SparkleCityHop
Living in 350Z
power bleeder?
Old Aug 15, 2013 | 07:43 PM
superman1128
Originally Posted by SparkleCityHop
power bleeder?
no just bleeding it manually
Old Aug 15, 2013 | 07:52 PM
SparkleCityHop
Living in 350Z
That's what I meant. Maybe try a power bleeder to make sure you have it fully bled.
Old Aug 15, 2013 | 08:05 PM
hurleysurferr's Avatar
hurleysurferr
50/50 that if you break pressure in the line the master will go bad to
Old Aug 15, 2013 | 08:06 PM
hurleysurferr
Zspeedperformance ... Heavy duty master and Slave cylinders ordered mine 2 days ago along with my clutch and flywheel combo
Old Aug 16, 2013 | 03:18 AM
sk8r776's Avatar
sk8r776
I just went through this with mine after replacing a bad Clutch Master. Put the slave cylinder together. Air is probably in there. I pushed the slave together and then had a friend pump the clutch while i opened and closed the bleeder valve. Every couple of pumps i pushed the slave back together just to make sure it had no remaining air in it.
Old Aug 16, 2013 | 09:13 AM
terrasmak's Avatar
Bingo, you have to collapse the slave all the way to get the air out of it. I do it everytime i open the bleed port. PITA, getting both arms in there, one to work the wrench and one to compress the slave.
The bleed port design is crappy, the valve should be facing up. This is the reason you can not get the air out.
Old Aug 16, 2013 | 11:59 AM
sk8r776's Avatar
sk8r776
I just pushed it once then worried about the bleeder. then went back and compressed it again. only had to compress it 3 or 4 times. Wasn't difficult. And i used a deep wrench kinda L shaped to open close the valve. wasn't a pain, just tedious.
Uriyo_
Sep 8, 2021 08:46 AM
