Hatch won't open - HELP!
Old Aug 19, 2013 | 08:11 AM
arthur_z27's Avatar
arthur_z27
Default Hatch won't open - HELP!
Initially my hatch wouldn't close b/c the latch was not working. I've had this problem in the past and was able to solve the problem by fixing the actuator (https://my350z.com/forum/maintenance...ont-latch.html).
My hatch didn't latch yesterday so I started to take off the plastic pieces in the trunk to get to the actuator. As I was taking out some of the bolts to remove the metal bar that the actuator is bolted onto, I heard the latch activate. Thinking that something might have been lose and magically fallen back into place while taking things apart, I closed the hatch thinking it was good to go. Big mistake, b/c now the latch is closed, but the actuator probably is not working as it will not release the latch when the trunk button is pressed.
I tried to pull the emergency trunk release cord under the rear strut bar but nothing.
Does anyone have any other ideas on how I can pop the trunk open?
THANKS!!!!!!
Old Aug 19, 2013 | 01:45 PM
oldschool350z's Avatar
oldschool350z
The cord under the strut bar should work.. try again.
Old Aug 20, 2013 | 04:40 PM
Spike100's Avatar
Spike100
^^ Absolutely... If pulling the cord doesn't work, something is bent or significantly damaged. If that is the case, the repair is requires significant and expensive repair measures.
--Spike
sherm
Apr 11, 2020 05:21 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
BOATS N HOES
Lighting
Oct 13, 2015 09:07 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
