Is my engine seized??
Old Sep 16, 2013 | 06:25 AM
mrathell's Avatar
mrathell
Default Is my engine seized??
I have a 2005 G35 coupe automatic with 60K miles on it.
Fo the past several months my G has been sitting because of an issue with the immobilizer/NATS/CAN systems. The car cranks but doesn't start. I finally used Uprev to disable my NATS this past weekend but I couldn't start it.
So like I said, I've cranked it a couple of dozen times over the past few months while trying to troubleshoot the NATS problem and it cranked really easy.
The last couple of times I cranked it I did notice that it started making a dry metal rub sound but I assumed that was the rusty parts like the a/c compressor (wisconsin saltly winters).
But yesterday I went to go start the car but it wouldn't turn over, so of course I think the battery is too low, so I charge it. Unfortunately the same reaction after charge.
Next I put my wifes car battery in there with the same result and the same result with my car battery.
So now I'm thinking the starter is fried, so I take it off and run it up to Autozone but it test good.
Then I decide to put a breaker bar on the main pulley and pushed in the closkwise direction (to the right/towards the drivers side) and it wouldn't budge.
Is it possible for the engine to seize from just cranking it?
Old Sep 16, 2013 | 06:29 AM
POS VETT's Avatar
POS VETT
That does sound like the engine has seized. I doubt it's caused by not the no-start problem. All I could think of was a valve might have dropped.
Old Sep 16, 2013 | 06:42 AM
mrathell's Avatar
mrathell
My assumption was that maybe one of the connecting rod bearings seized to the crankshaft.
I just never thought that either of those scenarios would/could happen at such low revolutions fom just cranking the engine and the engine temp not even really increasing because it wasn't running.
Old Sep 16, 2013 | 06:45 AM
iideadeyeii's Avatar
iideadeyeii
Oil up the cylinders through the spark plugs and try to manually crank with them removed. Best of luck
Old Sep 16, 2013 | 07:00 AM
mrathell's Avatar
mrathell
I will give that a try tonight. I'll let you know how it goes.
- I will remove all of th spark plugs.
- Put about a cap full of oil in each cylinder.
- let is sit for about an hour.
- then put the breaker bar on and see if it turns (with the spark plugs still out).
Old Sep 16, 2013 | 07:24 AM
djamps's Avatar
djamps
flooded with enough fuel to hydro lock? pull plugs and try cranking again.
Old Sep 16, 2013 | 07:54 AM
terrasmak's Avatar
That would be my first thing to try
Old Sep 16, 2013 | 08:02 AM
mrathell's Avatar
mrathell
Ahhhhh, I get what you're saying. Due to the constant cranking with no spark, fuel was just being dumped in there, so eventually it behaved the same as a hydro lock.
I'll pull those plugs tonight and give it a try.
Old Sep 16, 2013 | 02:03 PM
superchargedg's Avatar
superchargedg
Damn Noobs
dont use regular oil just use some of marvell mystery oil....it works but will smoke like hell till its burnt out.
Old Sep 16, 2013 | 06:42 PM
mrathell's Avatar
mrathell
Ok so I removed 5 of the 6 spark plugs. The middle plug on the passenger side will not budge. I tried it with a breaker bar and then resorted to the impact wrench to no avail.
So now I have it soaking overnight in a pool of Liquid Wrench penetrating oil.
Hopefully in the morning it will come out.
I'm assuming this cylinder is the cause of the reason the engine will not turn over.
I took the spark plug out about 2 months ago with no issues and the car hasn't ran so I don't know what would of caused for it to seize up in such a short time.
Old Sep 16, 2013 | 07:48 PM
djamps's Avatar
djamps
+1 on MMO. **** is magic.
But yea, be careful with that seized plug...if you break it your in a world of hurt with those deep tubes. Next time u install plugs use a sh!tload of anti seize.
Old Sep 17, 2013 | 04:42 PM
mrathell's Avatar
mrathell
So it soaked overnight in penetrating oil overnight and most of the next day. when I made it home I first tried it with a hand ratchet, no luck. so then I tried it with the impact wrench (electric), no luck again. The impact began getting really hot after a couple of minutes of constant impact, so I stopped.
So now I have it soaking in PB Blast. I'll leave it overnight again.
Given that this may be the hydrostatic lock, I will remove the fuel injector this weekend to relieve the pressure if the spark plug doesn't come out tomorrow.
Old Sep 20, 2013 | 09:10 AM
str8dum1's Avatar
str8dum1
impact on a spark plug? yikes... if it does come out, its probably going to bring the threads on the head with it
Old Sep 23, 2013 | 04:08 AM
Skrilla's Avatar
Skrilla
What ended up happening
liqalu04
Jan 2, 2022 12:58 PM
3vilbunny
Jul 18, 2017 05:10 PM
Fixxxercask
Nov 9, 2015 11:10 AM
