Help! Slips light comes on while driving.
Old Oct 9, 2013 | 07:50 PM
350zHerm's Avatar
350zHerm
Default Help! Slips light comes on while driving.
Just the other day I was coming home on the freeway & I was going about 70-75 mph on the freeway & my car would lose power & the slip light would come on. It happen multiple times driving back home on the freeway. I'd let go of the throttle & get back on it after it slowed down than get back on the throttle & run perfect again.. Any ideas what would be causing this? Help please it's a DD.
Old Oct 9, 2013 | 08:09 PM
terrasmak's Avatar
Tire sizes please
Old Oct 10, 2013 | 09:12 PM
Sponge's Avatar
Sponge
Terrasmak is on track
Check your tires for excessive wear and or the correct tire sizing. With factory sizes, computer may think the tires are slipping because the rears are much smaller in diameter than expected (i.e really worn) and rotating too fast in relation to the fronts. New rear tire ALWAYS fixed this issue for me. If you have a square setup, swap tires front to back and see if this solves the issue. If you find a bolt on the rear hubs is keeping your stock wheels from fitting, get all new rims and tires....or just remove the bolts
Old Oct 11, 2013 | 03:35 PM
350zHerm's Avatar
350zHerm
Tire sizes please
Thanks!
350zHerm's Avatar
350zHerm
Thanks so much. I'll keep you posted.
Old Oct 11, 2013 | 06:11 PM
Waiz's Avatar
Waiz
As per the Top 100 FAQ:
https://my350z.com/forum/4936171-post42.html
I would recommend you read the whole thread since you are still new to the forum:
https://my350z.com/forum/2003-2009-n...ml#post4936171
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
350z82
Oct 1, 2015 06:25 PM
samansharif
Sep 25, 2015 12:31 PM
