Weird overheating problem[i need help bad!!!]
Old Oct 10, 2013 | 09:57 AM
BabyGod{Z}illa's Avatar
BabyGod{Z}illa
Exclamation Weird overheating problem[i need help bad!!!]
OK I HAVE A 2005[35TH ANNIVERSARY EDITION] 350Z WITH 145K MILES ON IT,
I CHANGED THE:
  • WATER PUMP
  • THERMASTAT
  • WATER VALVE
  • RADIATOR
  • COOLANT TEMP SENSOR
And the damn car still overheats?
Idk whats wrong with it, I even took it in to the dealership and after 4 days of studying it they couldnt find the problem so the suggested to junk it, but I Love Z when I get tired of my SRT-4[Don't Judge].
Can I please get all the Opinions and ideas please.
Old Oct 10, 2013 | 10:20 AM
kham25's Avatar
kham25
What about the cooling Fans? Are they turning on
Old Oct 10, 2013 | 10:33 AM
BabyGod{Z}illa
Exclamation
Yeah they work sort of, what they do is turn on and off once, and when they turn back on for the second time they stay on and don't come off and that is when my temp needle moves up.
Old Oct 10, 2013 | 10:38 AM
iideadeyeii's Avatar
iideadeyeii
Get the air out of the system
Old Oct 10, 2013 | 10:43 AM
BabyGod{Z}illa
I did that too through the bleeder screw towards the back of the engine,
also what is the proper way of doing that?
Old Oct 10, 2013 | 11:08 AM
RedBullRR's Avatar
RedBullRR
Blown Head Gasket?
Otherwise you have a ton of air in system.
Lift front of car slightly so radiator is sitting higher then motor, invest in a spill free funnel and continue filling up till you see all bubbles go away while motor is on. Rev to 4K a few times till heat starts coming out of your vents.
Old Oct 10, 2013 | 11:31 AM
BabyGod{Z}illa
i'LL TRY THAT REDBULL, THAT'S SOMETHING NEW TO TRY?
Old Oct 10, 2013 | 11:39 AM
BabyGod{Z}illa
What else can i do if that doesnt work?
Old Oct 10, 2013 | 12:10 PM
BabyGod{Z}illa
The car doesnt over heat until the second fan kicks on. Once its on it will not turn off. As mentioned we have replaced the water pump, thermostat, coolant temp sensor, spark plugs, oil & filter, radiator and the heater connector. The heater comes on sometimes it just blows cool air. If i keep the revs above 3000rpms the heat comes through, but as soon as I drop it to idling rpms it goes cold again?????
Everything is working correctly, but its overheating. The engine isnt even hot and you can touch it it a little. The radiator cap is also cool. The lower in take hose from the radiator into the thermostat is also cold, while the return into the radiator is hot.
Any help right now would be appreicated...Thanks
Old Oct 10, 2013 | 01:29 PM
The REAL PigPen's Avatar
The REAL PigPen
The Heater blowing cool or ambient temperature air is a VERY good sign that there is still air in the system. I agree with RedBull as well with the "elevated" bleed technique but make sure you are on a flat surface before you do it. If you have a normal, graded driveway you should only have to take the car up a few inches.
Old Oct 10, 2013 | 04:17 PM
BabyGod{Z}illa
When should I rev up to 4k while the spill free funnel is attached, or what.
and while the car is on we are supposed to fill the radiator back up, and how would we know exactly when all the bubble are gone, because once it hits normal temp it starts to boil a bit. So can you please give us detailed step by step instructions please.
Old Oct 10, 2013 | 07:27 PM
cudaben's Avatar
cudaben
are u sure ur new thermostat is opening?????
i have spent many a hours diagnosing problems with car when the new parts were installed and that they "couldn't possibly be bad".
sounds like its stuck to me. check the simple things first, if u have gotten all the air out of the cooling system check to make sure ur t stat opens.
and the cold air thing, really makes me think its not flowing the coolant...
Old Oct 11, 2013 | 04:51 AM
mcarther101's Avatar
mcarther101
What thermostat you use? I installed a duralast one, it was brand new and didn't work. Reinstalled old OEM thermostat, and it was fine.
Old Oct 11, 2013 | 06:53 AM
tcode's Avatar
tcode
A bad radiator cap can make bleeding coolant system impossible. You bleed it, and soon the air is back into the system through bad radiator cap. It's inexpensive, change it if you didn't already.
Old Nov 4, 2013 | 09:16 PM
cudaben's Avatar
cudaben
no update, so its safe to assume it was something dumb???
Old Nov 5, 2013 | 12:16 AM
350Zdj's Avatar
350Zdj
Was probably low on coolant fluid lol
Old Nov 5, 2013 | 03:19 AM
mcarther101
I'll bet the new thermostat was a POS, and the dealer raped him with a new financed 370z , then sold his "junked" '05 for a profit after installing another thermostat lol.
Old Nov 5, 2013 | 02:00 PM
Spike100's Avatar
Spike100
It’s very unusual to get stumped when solving an overheating problem.
Originally Posted by BabyGod{Z}illa
…And the damn car still overheats? Idk whats wrong with it, I even took it in to the dealership and after 4 days of studying it they couldnt find the problem so the suggested to junk it, but I Love Z when I get tired of my SRT-4[Don't Judge].….
The dealer certainly has the resources to solve this. If “they [the dealership] couldn’t find the problem so [sic] they suggested to junk it,” it was probably a serious problem (i.e., a warped head allowing coolant into the engine).
A warped head that allowed coolant into the engine would mean the engine is shot and now the car is gone… and, BabyGod{Z}illa is possibly gone from here as well.
--Spike
Old Nov 5, 2013 | 09:16 PM
350Zdj's Avatar
350Zdj
lol. Funny that is exactly what happened to my engine few months back.
My coolant level mysteriously kept draining without any signs of leak. One day the engine just stopped. Boom! Warped head. Found some coolant in the exhausts
Old Nov 7, 2013 | 06:52 AM
BabyGod{Z}illa
Sorry Dudes, work has been busy.
But it was a warped head gasket that wasn't even all the way around, and it had pieces of the heater connector in the radiator.
So we dissected the engine and cleaned everything up.
It runs like a champ.
