Possible bad TCS/SLIP system?
So the other day i hit a wet patch and the Z slid out and the SLIP light flashed then went off... Fast forward to today same thing around a sharper corner and it slid pretty good but gripped back no SLIP or TCS light i said hmmmm ok I put it in 2nd and mashed it around a corner and did a nice little drift it was semi wet but the lights still never flashed. The TCS is ON i never turn it off.
My question is something wrong, disconnected, wheels/tires affecting it, being alitle wet causing the car not to use TCS or is this normal? I only have 33k bought it from my dealer it went through saftey and i dont drive hard at all.
Your car is behaving as expected. TCS is not the same as VDC.
You can slide all over the place and never activate TCS. Activating TCS requires slipping (loss of traction) while applying power to the rear wheels. TCS won’t activate if your rear wheels spin at near the same rotation.
--Spike
--Spike
--Spike
--Spike
